04-10-2007, 04:37 PM | #1 |
6 Lug drum to 5 Lug disk rear end?
I'm converting a 12 bolt 6 lug posi on a 68 SWB to a 5 lug disk.
I have seen a few kits for just axles and some disk setup's....... Looking for advise who makes the best axle kits and disk setups? Any adivise on a good source is greatly appreciated......
68 CST SWB - Gold/White 50th anniversary /TH350/Buddy Buckets/3.73 Posi/dogdish caps. 68 K10 Burb - Gold/White 327/SM465/NP205/3.73 "Daa Burb" build thread |
04-10-2007, 04:44 PM | #2 |
Re: 6 Lug drum to 5 Lug disk rear end?
not sure about the axles, i know there's a difference and somebody else here will comment on the conversion kits....
As far as disc brakes, glock35ipsc has been making brackets to allow you to swap to 94-96 Impala rotors and calipers, and is currently working on brackets for camaro calipers which will allow you to retain the E-brake. This swap would save you alot of money in the long run over aftermarket kits as the parts are readily available at a fair price. the link will take you to his for sale thread, which has lots of information. http://67-72chevytrucks.com/vboard/s...d.php?t=222628
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
04-10-2007, 06:29 PM | #3 |
Here is another board vendor with very reasonably priced disk options. I just ordered mine from them.
http://www.blackbirdscustomtrucks.com/
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
04-10-2007, 06:38 PM | #4 |
i converted my 12 bolt six lug in my 70 short c-10 and used cpp's rear disc kit and used a set of five lug yukon axles. the kit bolted write up with no problems and it was a complete kit. i was miss lead though i had to purchase a disc/disc master cylinder to make the brakes operate properly.
70c10 ZZ4 700r4 |
