09-06-2002, 05:19 PM | #1 |
Slowly getting CRSS...
Factory Valve cover Coating
What is a good way other than scrapeing and scratching the aluminum to get the plastic like coat off my factory 91 valve covers? It is chipping b/c its lie some kinda plastic deal and i wanna put them back on the motor till i get roller rockers. I was gonna strip and powdercoat em.
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
09-06-2002, 09:18 PM | #2 |
I'm not sure but I think that maybe letting the valve covers sit in some muriatic acid would do the trick. Let them sit a while and then scrapping off would be a snap, but make sure to be safe with the acid, and don't just dump it in the yard/drain when you're done!
1967 GMC Custom 8ft Fleetside 292 L6, 4spd. 1973 Oldsmobile Delta 88 Convertible 455, TH 400 1969 F#$% Bronco 302, 3spd 4.11's 1958 Oldsmobile Super 88 Fiesta Wagon |
