Old 04-10-2007, 05:55 PM   #1
cruzito1
rear disk brake conversions
I have a 63 chevy stepside longbed
it has a 350 engine and trans from a camaro
and a disk brakes from a 88 chevy 1500
I still have six bolts on the back and the new 5 by 5 bolt pattern in the front
Im trying to match the bolt pattern for the back
So I was thinking of changing the rear end to disk brakes
I don't have a lot of money because my wife is close to divorcing me cause of the truck and the time I spend on it
I use craigslist to find deals on parts
sometimes they fit and sometimes they dont
so my back yard has a lot of extra stuff that didn't fit
My question is...
What is the most inexpensive way to get my rear end to have the same bolt pattern as the front?
Do I have to change the whole rear end?
Or is there a way of just changing the axles that go to the drums
or should I just buy a rear end that has disk brakes on it?
I guess I could just look for six lug disk brakes too?
The thing is that I was amazed on how easy the spindles and rotors fit into where the drums where. I was kinda hoping that It would be just as easy to switch out the rear drums for disks too.
I heard that 72 to 87 spindles fit right in and even though they came from an 88 chevy 1500 it still worked.
I hope someone out there knows what Im trying to say or ask....
Theres some dropped spindles for a 92-98 1/2 ton truck, would they fit my 63?
respectfully,
Carlos
cruzito1 is offline   Reply With Quote
Old 04-10-2007, 06:04 PM   #2
derail
derail's Avatar
Re: rear disk brake conversions
You can buy 5 lug axles from early classic enterprises. If you have a 12 bolt rearend.Here's the link.http://www.earlyclassic.com/catalog.aspx Click on the choose category and you should see axle replacements there.
derail is offline   Reply With Quote
Old 04-10-2007, 07:04 PM   #3
steverino66
I'm checking into having a machine shop re-drill my 6-lug rear hubs (and drums) for 5x5 - possible cheaper solution?
steverino66 is offline   Reply With Quote
Old 04-10-2007, 08:33 PM   #4
BIGPIMP
PIMPING RIDES
BIGPIMP's Avatar
they run $ 279 plus shipping and they work great .
1964 CHEVY 1/2 C/10 FLEET
1981 CHEVY 1/2 C/10 FLEET
1995 DODGE 1500 V6 FLEET
EAST
http://www.flickr.com/photos/bigasspimp/?saved=1
BIGPIMP is offline   Reply With Quote
Old 04-11-2007, 02:13 PM   #5
cruzito1
Thank you for your replies
Im going to look into the machine shop option first and if not 279 dollars sounds really good as a back up option to solve my head aches
It seems that when trying to save money, you end up spending more in the long run.
Again thanks you for everything.
respectfully,
Carlos
Old 04-11-2007, 10:46 PM   #6
65 on 24's
65 on 24's's Avatar
im swaping to disk in the rear in mine and i just got my disk to day the only thing your going to get a 5 lug rear end out of that has the same lug patter and is a disk a impala ss bubble or a bubble capric cop car
ridin big yo
5in cpp lowerin springs in back
lowered 3in in front with cut springs for now
5 lug swap and disk in front
5 lug and disk in the rear with 3.23 gears
mild 350/400heads
7547weiand intake
600 Edelbrock
chrome block hugger headers
2 1/2 pipes in to a x pipes
super 40 flows and turn downs
turbo 350 with shift kit
65 on 24's is offline   Reply With Quote
Old 04-12-2007, 08:50 PM   #7
cruzito1
What exactly is a impala bubble top?
I found a rear end of a 1995 impala for 150
but the guy says it has rear brakes with 4 3/4 bolt pattern
I don't think they made one like that did they?
Respectfully,
Carlos
Old 04-12-2007, 09:03 PM   #8
cruzito1
I forgot to put exactly what the add says:
1995 Impala rear end
This rear end has dis brakes bolt pattern is 5 on 4on 3/4 also has limited slip dont know what gears are in it . all hangers have been removed. great for project car.
Old 04-12-2007, 09:05 PM   #9
cruzito1
oh and whats "limited slip" mean?
Sorry for pestering with so many questions
but any help is greatly apreciated.
Old 04-12-2007, 11:25 PM   #10
PrerunnerRob
PrerunnerRob's Avatar
Limited slip is a device that locks both axles together, aka posi, that will hold them together until a larger traction forge is exerted up one alxe, breaking the limitation (the limited portion) of the of a preload placed between both axles. I hope this helps!
PrerunnerRob is offline   Reply With Quote
Old 04-13-2007, 10:19 AM   #11
65 on 24's
65 on 24's's Avatar
that should be it
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 04-13-2007, 11:17 AM   #12
Jonboy
Slots go on anything!
95 Impala will be 5 on 5 bolt pattern. Should have 3.08 ratio, if it hasn't been changed.
Old 04-13-2007, 12:58 PM   #13
65 on 24's
65 on 24's's Avatar
i no mine come out of a 94 bubble capric and it has the same lug patter cuz we put my wheels on it
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 04-18-2007, 12:39 PM   #14
cruzito1
I picked up the 95 impala rear end today
is there anything special I need to look out for when swaping it out?
I got a power booster and a master cylinder off a 1979 c 10
I plan on getting a proportioning valve from jegs for like 40 bucks
does anyone know if its going to fit right in or if I have to make it narrower or wider?
Thank you guys for all your help.
This is the first time I used this message board.
And Im kicking my self in the butt,cause I should of done this sooner
I guess I was kind of intimidated by all you experts out there.
65 on 24's did you already put this rear end on yours?
Old 04-19-2007, 10:12 AM   #15
65 on 24's
65 on 24's's Avatar
you should not have to narrower it or make it wider i think the one in the truck is 56 in and the disk brake rear end is 56 in. no i have not put it in i need a axle and i need the kit from CPP for the pan hard bar you will need it to. im not hookin up the e brake im going to use the axle perch off my old rear end. im going to start on mine after this week end cuz super chevy show is here this week end and im going to try to get all my stuff there.
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 04-23-2007, 10:05 AM   #16
65 on 24's
65 on 24's's Avatar
i was at the supper chevy show this week end and i seen a 67 with rear disk brakes and i was thinkin they where bear cuz that what he had on the frunt of the truck but i got down and look and it was the same set up as we are doing
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 04-23-2007, 01:13 PM   #17
dallas71
dallas71's Avatar
if you were closer i have a spare rear end that i could hook u up with that is ready to go (5 -lug)
dallas71 is offline   Reply With Quote
Old 04-23-2007, 10:53 PM   #18
BigTruckDriver
BigTruckDriver's Avatar
I did this and if I had to do it again I would just by the new ones. I had the axles weld ed in and re drilled then I had to get them turn on a lathe to accept the later 5 lug drum. The center of the axle did not fit on the new drum. It totaled out to about 175 and I still had my OLD axles.
BigTruckDriver is offline   Reply With Quote
Old 04-24-2007, 10:31 AM   #19
65 on 24's
65 on 24's's Avatar
what are you talking about
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 04-24-2007, 10:59 AM   #20
BigTruckDriver
I thought the guy was asking about switching from current 6 lug to 5 lug axles. It was late
Old 04-24-2007, 11:08 AM   #21
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Try this kit there reasonably priced. http://www.tsmmfg.com/
gulfcoast66 is offline   Reply With Quote
Old 04-24-2007, 12:33 PM   #22
65 on 24's
65 on 24's's Avatar
how is that reasonably? add all that up it $654.95 cpp kit is only $599.99 . you can get the hole impala or caprice rear end cheper than that i got my rear end for $25 cuz it had a broke axle and dude need mony to get a new rear end from the juck yard but i have seen good one on ebay for about $250 and outher places for about $300/ $350
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 04-24-2007, 12:38 PM   #23
65 on 24's
65 on 24's's Avatar
i have been lookin for the last year to do a rear disk brake and i have not found and thing cheaper that doing this
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
Old 04-24-2007, 02:14 PM   #24
gulfcoast66
64-66 CHEVY JUNKIE
I donno what kind of math you are doing 65 on 24"s. but for 459.95 the kit,calipers and hoses to complete the job is not bad, and the 6 lug or less then that. All im getting is the kit for 289.95 per pair. As for calipers junk yard, 79-85 Caddi seville, el-dog, or olds. toranado , Buick riviera, front wheel drive cars rear calipers will fit this kit. Autozone may have them at a good price. (shipping to where im at is only 21.55.) You cant beat that with a blender!
Old 04-24-2007, 05:34 PM   #25
65 on 24's
65 on 24's's Avatar
289. 95 is for backin plate and rotors only y order from there and then have to go find pice here and pice there why not just buy a hole rear end from the junk yard. i was if you are order every thing from them
ridin big yo
mild 350/400heads
7547weiand intake
600 Edelbrock
