Old 04-10-2007, 10:12 PM   #1
slepysal
slepysal's Avatar
ignition coil fun.
So My truck had a miss ,or should I say it would "flaten" out at higher rpms It has the pertronix ignition and a blaster coil. I thought maybe it was my coil and swaped in my old one. I took it for a test and it did the same thing. I pulled in to my drive way and when I shut the truck off..... It kept running !!!!
I started to check the coil wires and when I touched the neg (-) wire ...
ZAAAPPPP !!! Yup a bad coil . I replaced my coil and the truck would shut off as it should.But still had thad "flat " problem.
So what was the problem? My choke. It was not opening all the way when I pushed the choke knob in, and fuel starving at higher RPM's. Easy fix, by addjusting the choke cable
I thought my truck was pissed off at me and going "Christine " on me!!
I guess I better go buy her something.
slepysal is offline   Reply With Quote
Old 04-11-2007, 10:30 AM   #2
desertrat
desertrat's Avatar
Re: ignition coil fun.
Glad it was an easy fix for you. I had a new pertronix ignition in my 41' and it went south, took me forever to figure it out. Now I won't run pertronix anymore.
desertrat is offline   Reply With Quote
Old 04-11-2007, 10:42 AM   #3
slepysal
slepysal's Avatar
Yea I keep my points in the glove box just in case. I have used the pertrnix on my 53 Wagon, and ny 64 Galaxie, never had a problem ( Watch I just jinxed my self )
