Old 04-10-2007, 10:43 PM   #1
RustMaster87
RustMaster87's Avatar
Any frame differences from 73-87?
I have a possible rolling chassis that is in far better shape than what I currently have for my 87, the chassis I am thinking of using is from a 73, or an 80. As long as it was a short bed 2WD, there shouldn't be any differences right? I have never worked on earlier than 87 so I just wanted to make sure I am not wastng money. My current chassis is an 87 2wd short bed, and is a mess.
RustMaster87 is offline   Reply With Quote
Old 04-10-2007, 11:23 PM   #2
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: Any frame differences from 73-87?
I know that as long os your fram does come froma 1 ton you ok cause a 1 ton is defrent the 1/2 or 3/4 it more narroew then that of the other two.
Also theres the tranny cross member but you have yours so you should be fine there as well. To the best of my knowledge you should be fine getting a frame from a 73 or an 80 to match your 87 short bed 2wd.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 04-10-2007, 11:31 PM   #3
DESTRO
body mounts are different. 73-80 and 81-87. You'll just have to get new mounts I think. Just get the mounts to match the frame.
DESTRO is offline   Reply With Quote
Old 04-15-2007, 07:28 PM   #4
Stano
Stano's Avatar
Destro is correct. The rubber mounts need to match the frame. The front of the frame rails will need trimmed so that the front bumper brackets will fit correctly. Self explanatory when you inspect the two side by side. The 73-80 has a upper bracket and the end of the frame rail is rounded. The 81-87 has a bracket that bolts between the bumper and the frame and the frame will need a piece trimmed off of it to clear the bracket. It is not difficult at all, it could be done with a hacksaw if thats all you got.
New daily driver 96 Chevy K3500 crew cab dually 53,000 miles 350 Vortec 4L80
Nice ride 67 Chevy C-10 LWB Built 350 TH-400
Wifes ride and family rig:
2001 Furd Expedition 5.4 Liter
Kickin back in Rolla,Mo. USA
"Do the thing you fear most and the death of fear is certain" Mark Twain
Stano is offline   Reply With Quote
Old 04-17-2007, 06:26 PM   #5
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
73-80 1/2T frames are heavier than 81-87 frames. They lightened up the crossmembers on the 81-87's.
Plus the front as noted above is rounded on the 73-80 and triangular on the 81-87.
Body bushing and mounts must match the donor frame not the body.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
