Old 09-06-2002, 07:21 PM   #1
chevyman02
Removing ignition switch?
Anyone else have any problems removing the ignition switch from the dash? I can't seem to figure this one out. Any help is appreciated.
Adam.
chevyman02 is offline   Reply With Quote
Old 09-06-2002, 07:27 PM   #2
woodrow59
OzarkHillbilly in Atlanta
try this thread
http://64.246.42.114/vboard/showthre...gnition+switch
72 custom/10 LWB
68 Longhorn C20 Custom Camper (sold)
woodrow59 is offline   Reply With Quote
Old 09-06-2002, 07:30 PM   #3
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Turn the key to the accessory possition, insert a stiff wire like a paperclip into the little hole above the key. You should feel some spring tention when the wire is pushed in. Continue to push against the tention then turn the key toward the left and the tumbler should come right out. Then unscrew the bezel and remove the ignition switch.... WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 09-06-2002, 07:55 PM   #4
chevyman02
The guy I bought it from didn't have the key. What do I do if I don't have the key?
Old 09-06-2002, 09:48 PM   #5
chevyman02
Anyone else run into this situation?
Old 09-06-2002, 10:03 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
My GMC also came without a key, it took breakig a couple screwdrivers, but I was able to hamme a screwdriver in and then turh it to the acc position and I used an allen wrench to push in the little hole...popped right out into my hand.
Old 09-06-2002, 10:42 PM   #7
jostrans68
Jostrans68
jostrans68's Avatar
I just did mine on the cab I got From WES no keys if you pop the chrome around where the key goe into tumbler kind of like the old metal brake fluid lids . its about as big as a nickle. then spin the outer ring off it will come of tight but it will come off. if you dont take the inner chrome of it will spin and strip ...Jack
[CGTW Member
former 67-72 now with a 96 silverado
jostrans68 is offline   Reply With Quote
