Old 04-11-2007, 01:50 AM   #1
pat
pat's Avatar
Column shifter knobs
Where did you guys get yours? Mine is all rusty. I bought a kit from Summit that only came with the knob, I need it all. Also bought another one off ebay that was supposed to fit my truck, but didnt, so I returned it.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s
64 Cadillac Sedan DeVille
pat is offline   Reply With Quote
Old 04-11-2007, 02:06 AM   #2
WinDancer
The Original HotRod KnifeMaker
WinDancer's Avatar
Re: Column shifter knobs
If you are asking about the column shifter arm and knob I just swapped mine out for one from a 1961 Impala.
I am collapsing part of the column to get more room behind the wheel [learned about his here!] and the shifter was then a little close to the dash. The Impala arm and knob are almost three inches shorter with a little more angle and clears everything just fine.
It is a very natural movement now to shift with a couple fingers without taking your hand off the wheel.
Part of the problem was also the Grant custom wheel being smaller diameter than the original wheel [like, what isn't smaller].
The move and the new shifter gives a lot of extra room
hth
Dave
69 GMC SWB 2WD 454 Turbo 400
WinDancer is offline   Reply With Quote
Old 04-11-2007, 03:17 PM   #3
pat
pat's Avatar
hth
I have a Grant wheel too and my shifter sticks out too far.
Thanks for the tip
