Old 04-11-2007, 11:47 AM   #1
beechcreek
72' 4x4 project
My question is i have a 3-speed on column, and want 4-speed in floor. What 4-speeds will work with my 72' 4x4 truck? And where may i start looking?
Also, what inch suspintion lift do i need to run 35" or 36" tires?
I hope this is in the rite forum.
Thanks for your help!
beechcreek is offline   Reply With Quote
Old 04-11-2007, 12:31 PM   #2
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: 72' 4x4 project
I would use a sm465 trans with a 205 TC.
A 4" lift will let you run 35" tires.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 04-11-2007, 03:15 PM   #3
beechcreek
Re: 72' 4x4 project
Can you use a 4 speed transmission out of a 72' 2wd. can the yoke be changed out so the transfer case will bolt up? Will the transfer case bolt up to the regular transmission.
Old 04-12-2007, 09:17 AM   #4
1969K10
1969K10's Avatar
Re: 72' 4x4 project
I'm not the expert on this, but you would have to take the tail off of the 2WD tranny, and maybe change out the rear shaft for a shorter one.
You could also run the X-fer "divorced style" which would involve a short drive shaft from the tranny to the X-fer.
What X-fer do you have? Some of those old I-6/3 spd combos had some kind of Dana X-fer. From what I understand, you won't want to run that behind a V8 in a full size P/U.
The more info you give, the better help you'll get from the guys that know their stuff on here...
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-12-2007, 02:15 PM   #5
1969 GMC
1969 GMC's Avatar
Re: 72' 4x4 project
You could, but then you'd have to use a divorced transfer case. 2wd SM465's have a 35 spline mainshaft and a different tailhousing with the speedo gear in it. You could swap it over to either 10 or 32 spline 4x4 setups, but that would require a complete teardown, and in my mind isn't worth it. 4x4 SM465's arent exactly rare, so it shouldn't be too hard to find one.
What I am not sure about, though, is if the adapter and drive sleeve off of your current tranny/transfer will fit on an SM465. I'm guessing you already have the NP205, but it's not totally unheard of for a truck to have a Dana 20. There are plenty of pics on this website so you can ID your t-case if you can't see the tag on it.
If you do have a Dana 20, you will need to source a complete SM465/NP205 combo. It can set you back probably 200-400 dollars. If you already have a NP205, you can probably get just the transmission for well under 100. If the adapter is different, you will need to find that too.
Good luck!
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
