Old 04-11-2007, 03:04 PM   #1
tranz am
tranz am's Avatar
Question Holly electric fuel pump help (pic)
OK I found this pump at a local junk yard under a big block powered P30. I plugged it in and it fires up. My question is what is the blue thing attached to it?
I would imagine its a regulator. I want to use this to feed my 800 cfm q jet thats bolted to my 400 horse 350.
Now if that is a regulator how do I adjust it and what should I adjust it to? I know that the q jets are more sensitive to fuel pressure so This is important to get right. So fire away if you can help thanks.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 04-11-2007, 03:18 PM   #2
Billla
Billla's Avatar
Re: Holly electric fuel pump help (pic)
Don't run the pump dry; fuel lubricates the pump
You're absolutely correct - it's a regulator. I suggest 6-7 PSI. The set-screw on the top of the regulator is how it's adjusted.
Billla is offline   Reply With Quote
Old 04-11-2007, 03:55 PM   #3
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
You shouldn't need a regulator on the holley red pump. It has a max pressure of 7psi. Here's a link to Holley.
http://www.holley.com/HiOctn/ProdLin.../12-801-1.html
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 04-11-2007, 04:27 PM   #4
Billla
Billla's Avatar
Good catch; I should have thought a bit more before responding.
Old 04-11-2007, 04:34 PM   #5
tranz am
tranz am's Avatar
I would imagine that a return line of some sort should be rigged up thou, right?
My build thread
1969 GMC SWB
Old 04-11-2007, 04:40 PM   #6
jojotonka
jojotonka's Avatar
I just purchased a Holley Blue pump, the directions said to mount the fuel pump as close to the fuel supply as possible and the regulator as close to the carb as possible. If that helps future plans at all.
Oh, they also said to mount the pump below the lowest point of the tank, to create a siphon effect, because these pumps are designed to push fuel not pull.
And they said to add an inline 7.5 amp fuse to the positive wire.
These were directions from a BLUE Holley, I'm assuming their the same, I could be wrong.
jojotonka is offline   Reply With Quote
Old 04-11-2007, 05:08 PM   #7
tranz am
tranz am's Avatar
I wonder why they want the regulator so far away?
My build thread
1969 GMC SWB
Old 04-11-2007, 05:22 PM   #8
BACKYARD88
BACKYARD88's Avatar
No need for a return line, the fuel pressure/volume isn't high enough.
It's more effective that way, less pulsation. A holley blue has a higher psi rating(I think 14psi but don't quote me on that one) so it requires a regulator.
-Mike Owen-
Old 04-11-2007, 05:35 PM   #9
tranz am
tranz am's Avatar
wouldn't the pump try to keep pushing the fuel after the needle and seat closed and destroy it self?
My build thread
1969 GMC SWB
Old 04-11-2007, 05:54 PM   #10
BACKYARD88
BACKYARD88's Avatar
It has a built in pressure relief. If you look at the tech instructions in the link it tells you how to clean the pump and relief. You might want to do it since it came from a salvage yard and might have been sitting for a while.
-Mike Owen-
Old 04-11-2007, 06:01 PM   #11
tranz am
tranz am's Avatar
Cool! just hook it up and go then.
My build thread
1969 GMC SWB
Old 04-11-2007, 06:37 PM   #12
kelsfine69
18 Till I Die
kelsfine69's Avatar
Heres how I mounted mine, Blue pump is right by the tank by the frame. Regulator by the carb. Bought a gauge to set it.
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 04-11-2007, 06:42 PM   #13
tranz am
tranz am's Avatar
Looks good thanks for the pic
My build thread
1969 GMC SWB
