Old 04-11-2007, 03:38 PM   #1
jeff1vol
jeff1vol's Avatar
? regarding my airbags & Leaking.
Do you normally lose air pressure after a period of time? I found myself having to refill my bags after it sat in the garage for a couple of weeks. They weren't totally out of air, just lower then they were when I parked it. Is this normal (like having to put air in your tires periodically) or do I have a leak that must be fixed? I had to put air in all four.
Obviously, there must be a slow leak somewhere. I don't have a compressor set up at the moment, I'm using 4 schrader valves presently. What is the best way to find the leak and where would you look first? In other words... where would they "most likely" be leaking air?
Thanks,
Jeff
jeff1vol is offline   Reply With Quote
Old 04-11-2007, 03:42 PM   #2
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
Re: ? regarding my airbags & Leaking.
Alot of systems will leak down over time but I have seen some that could go months at a time without loosing pressure. What type of fittings are you using? Also, I've found that using something like locktite instead of teflon tape helps.
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 04-11-2007, 03:50 PM   #3
jeff1vol
jeff1vol's Avatar
You know... I was just thinking that the weather
here in VA has gone from mid 70's-low 80's back down to the 30's and 40's this week. Do you think that the temperature may have something to do with it? Thanks for the information!
Old 04-11-2007, 04:09 PM   #4
BACKYARD88
BACKYARD88's Avatar
A temp change like that could result in quite a bit of pressure difference.
-Mike Owen-
Old 04-11-2007, 04:15 PM   #5
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
I wish mine stayed aired up that long. I would take some soapy water in a spray bottle and spray everywhere there is a possibility of a leak. If there is on then you will see it easily. This is what SSD suggest to use on fittings.http://*****************/FittingsLoct...eadSealant.php
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 04-11-2007, 04:27 PM   #6
jimmydean
jimmydean's Avatar
My drivers front goes flat in about 3 days, my passenger rear goes FULL in about 8 hours. The fill leak is from the valve not fully seating. I need to replace the valve, I just haven't.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-11-2007, 04:28 PM   #7
bagged69c10
You may just be able to clean the valve. What kind of valve is it?
1965 c-10 long bed
1993 Sierra x-cab
Old 04-11-2007, 11:06 PM   #8
jimmydean
jimmydean's Avatar
I've tried. It's a Parker valve and it's only $30 to replace. If I am going to go through the hassle of pulling it again, it is getting replaced. No sense in messing with it only to find it still leaks.
I have spent WAY too much time chasing leaks in this system that I nearly pulled everything out.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 04-11-2007, 11:17 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
They should not leak down. I leave my truck aired up all the time since I want to know about a leak "before" I get on the road. It's always just like I left it...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-12-2007, 07:07 PM   #10
n2billet
Village Idiot....
n2billet's Avatar
Must be quality work
n2billet is offline   Reply With Quote
Old 04-12-2007, 11:47 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
I have the best installers available....
Articles-
"Refining Sierra"
Old 04-12-2007, 11:59 PM   #12
72CSTC5
72CSTC5's Avatar
Hey what about that mishap that I heard about?
72CSTC5 is offline   Reply With Quote
Old 04-13-2007, 07:14 AM   #13
n2billet
Village Idiot....
n2billet's Avatar
Yep, I was being a little sarcastic. We all remember the Jiffy Lube story!
Old 04-13-2007, 09:28 AM   #14
Chops_by_Chase
Chops_by_Chase's Avatar
my pressure doesn't change, it stays up for weeks, but my truck is just being rolled in and out of the garage. you should be able to have a leak free system...
Chops_by_Chase is offline   Reply With Quote
Old 04-13-2007, 12:34 PM   #15
SCOTI
SCOTI's Avatar
Gravy brother. . ..... gravy.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-13-2007, 12:59 PM   #16
1lowdiesel
1lowdiesel's Avatar
yea you shouldn't leak at all. i use legris fittings and they are the only one's i trust.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
