![]() Join Date: Apr 2007
Help with camber issues when lowering
I have been trying to get all the parts that I need to drop my 69 gmc and ran into an issue. One of the sales persons I talked to told me that If I used three inch drop springs I would have camber issues. I'm guessing the top of the wheels would be leaning towards the outside of the truck, correct? what can I do to eliminate this? thanks
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 04-11-2007 at 05:04 PM. |
![]() Join Date: Oct 2005
Re: Help with camber issues when lowering
As you lower the truck the upper A-arm is pivoting towards the center of the truck, so the top of the tire will lean in (negative camber) causing your tire to wear on the inside first. The stock bolts that hold the A-arms may not be long enough to adjust for this.
Probably the best solution for this is aftermarket A-arms.
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
#3 | |
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht |
I am a Referee of life.
How low are you trying to go?Usually anything over 2 in drop with springs will cause problems with alignment.Using 2 1/2 or 3 in drop spindles is a better way to lower.More than that usually requires new control arms and maybe reworking the crossmember(or using a "Porterbuilt")
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
67 chevy SWB Fleetside
fully agree, use the drop spindle and everything will ride better too
67 Chevy C10 Short Wide 350/350 ... Front Discs ... ECE Lowered 2.5/4 Vintage Air ... Oak Bed Floor ... Painless Wiring Brothers 1 pc Windows ... Lokar Pedals, Shifter, E-brake Ididit Column ... VDO guages |
Im about to buy the 2 1/2 drop spindles. unless I can get more. I want to use 3 inch drop coils in conjunction with them.
The 3 inch drop coils im looking at buying are for 67-73 but I want to use them for my 73-78 setup. I imagine the springs are the same considering most everything elts in that region is.
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=456220 Best 1/4 mile time 12.1 @ 111 w/traction issues 1969 GMC SWB 1964 chevy II Nova ht Last edited by tranz am; 04-11-2007 at 05:59 PM. |
Questionable
http://www.classicperform.com/6092chevtrk.htm
Look for their tubular A-Arms. That's what I'm buying, for several reasons. 'Quality product' is all I keep hearing from people whove installed them.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I've done a lot of 3 inch drop springs. As long as your control arm bushings and ball joints are not worn out, there will be enough thread on the upper control arm studs for shims to set the camber. I've never needed aftermarket control arms.
Cool! Thanks for all the info.
#10 | |
A guy with a truck
Careful. Guys in the suspension forum are having trouble with these as of late. The welds are preventing them mounting the upper ball joint.
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
From what I understand 3 inch is the limit anything more and you are in trouble.
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
Active Member
I used the ones in the link below and couldn't be happier. Their service is top notch!! http://performanceonline.com/store/c...cat=788&page=1
1971 SWB SOLD
#13 |
Thanks, Ill check it out.
#14 |
What if you use longer control arm studs to shim the arms??
#15 |
F.A.S.T. president
![]() Join Date: Sep 2003
With -3" (or -2" sorry cant remember) springs and - 2 1/2" spindles my caster moved in 1/2" (about 2 degs) if measured at the rim edges using a level as a guide.
I made some 1/2 spacers to replace the 1/4" stack of shims that are on there now so I don’t have to have such a large shim stack. I plan to put them on this weekend I will take some pics and let you know how it worked out.
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 04-14-2007 at 07:10 AM. |
#16 |
Yea Id like to see them. Thanks
