Junior Member
67 3/4 ton rearend
has anybody heard of a H206140 rearend? mine is an eaton but all i see is info about H2052
its all about the +6 inches
Re: 67 3/4 ton rearend
Never heard of any of that. If your 67 is original, it would be an HO52, with an HO72 being in the one ton trucks.
Where did you get that number from?
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Junior Member
I got # from top of hog head along web. Here are some pics
that is a corerate rear, with an eaton differential in it... called an HO52.
Junior Member
Thanks for the clarification. It looked like other H2052 rears that had been posted.
HO52... not H2052
Junior Member
are the numbers stamped on the rearend, or can you look at the rearend and tell?
Cantankerous Geezer
If the rear cover is fairly round and has 10 bolts holding it on, it should be an HO52 on a 3/4 ton.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Junior Member
so i take it that they don't have H052 stamped on them and the number stamped on mine is not the model number?
