Old 04-12-2007, 10:04 AM   #1
Yeller68
Active Member
Yeller68's Avatar
Seat belt retractors, how to remove???
I've searched the forum, I've spent hours staring at mine, I give up!!! How do you get these things off? The cover over the retractor is very tight, and I can't find any way to remove it without risking tearing it. Anybody got any hints?
Yeller68 is offline   Reply With Quote
Old 04-12-2007, 10:58 AM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: Seat belt retractors, how to remove???
Is your seat in the truck or out?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-12-2007, 11:02 AM   #3
Yeller68
Active Member
Yeller68's Avatar
It's in now, but will probably be out in a couple of weeks for recovering.
Old 04-12-2007, 11:42 AM   #4
EAST SIDE LOW LIFE
EAST SIDE LOW LIFE's Avatar
This is going to sound off beat but here goes. I extended the belt and put a little vasoline on the edges of the metal male tang being careful to not get any on the belt webbing and pulled the male tang through. Slow and steady is the trick.
Now if your trying to remove the retractor totally off the floor just wiggle the boot cover back and forth and you will soon see it start to relax and come off exposing the bolt.
Why are you wanting to remove it? If your redoing your seat it is not something you have to do.
esll.
Tomorrow is for doing today's stuff.
This truck has just the right amount of energy for me!
Author: Warren Lake .... (member)
EAST SIDE LOW LIFE is offline   Reply With Quote
Old 04-12-2007, 12:00 PM   #5
Yeller68
Active Member
Yeller68's Avatar
Main reason is just to get them, and be able to clean them up as much as possible. Second reason is I'm considering buying one of the 3 point systems, and replacing it. While I want to keep it original as possible, I have a greater desire to keep my face out of the dash in case of an accident. Also in the back of my mind is how strong can 40 year old belts be?
Old 04-12-2007, 01:21 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-12-2007, 02:31 PM   #7
EAST SIDE LOW LIFE
The webbing is quite strong and the pattern of the webbing adds to the strength. You'll notice in most cases what is called ribbing is the pattern of the belt which runs one way and then the opposite way until the desired width of the belt is acheived. Check the stiching if it is good then it is fine, if it needs repair go to a shoe renew shop and get the guy to over stich it in the same pattern as original as this is also designed for max. strength. Buckles don't work very hard unless they have been strained in a accident. Even then insurance companies don't usually replace them.
To clean them or replace them you are going to have to work with them until they free up. With the seat out or in it makes no difference as the boot has to come up to remove the retractor.
esll.
The boot is pretty thick if your careful you should be ok.
