Old 04-12-2007, 01:11 PM   #1
rcbildr
rcbildr's Avatar
84 Suburban Fuel Pump Question
I'm working on an 84 Suburban that originally had a 454. I noticed there are 3 hoses for the fuel pump. Is the 3rd hose a return line, and did the 84 'Burbs with a small block have that same set up? Any help will be greatly appreciated. Thanks!
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 04-12-2007, 01:24 PM   #2
fosheec
fosheec's Avatar
Re: 84 Suburban Fuel Pump Question
The 3rd hose is a return line. I believe just about all the trucks after 71 or 72 had this due to emissions. I could be mistaken though.
Caleb
fosheec is offline   Reply With Quote
