C10 Club Tennessee
Does anybody see anything wrong with using this shroud?
Since I've given up on the electric fan idea for a while. I decided to put the regular fan blade with fan clutch on. Problem is it is hitting my original shroud. I've trimmed the shroud and I've trimmed a little off of each of the five blades. Still no luck. Does anybody see a problem with using one of the old six cylinder shrouds? Of course I'd clean it up and paint it or have it powdercoated. Some may not like the look but thought I'd ask.
Or should I just not run one at all?
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
![]() Join Date: Nov 2004
Re: Does anybody see anything wrong with using this shroud?
It might not cool well enough. My six popper used to overheat in the summer with it. I put the full shroud on and the problem went away
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
No expert, but I don't think it will help much.
BTW- Is it just the pic or is your upper radiator hose kinked right there at the back of the alternator?
05 2500HD 6.0 excab 69 LWB-Gone but not forgotten! 68 Dodge Charger 383/727 69 Dodge Charger-440/4spd |
its all about the +6 inches
I've run those on the last 2 trucks I've had, on the longhorn with the cad engine, I had to 'unbend' it a little to keep it off the fan.
It does do a little to aid in proper airflow, but mostly, it'll help keep you from havin a finger chopped off. I say run it if you can. I've never had any cooling issues running this... or even no shroud for that matter. I don't know why, but my combination of marginal parts always seems to provide me with flawless cooling. On a side note... it is a very bad idea to trim a fan... just a few grams difference from one blade to another can damage the water pump once at speed. Last edited by Longhorn Man; 04-12-2007 at 01:40 PM. |
GEARHEAD
The one in the first two pic's is not so much a fanshroud as it is a guard. I don't think the originals look that bad tough. For best function you need one that surounds the fan and creates a tunnel to draw air through the rad. Like the stock plastic one do. like in pic.
GEARHEAD
I agree with Andy on the fan blade trimming not a good IDEA.
RACINJASON22, what is that shroud off of? Is it factory, I've never had a factory one so I wouldn't know if I saw one..
With that serpentine setup a fan shroud from a BB truck should work thats what I had to use on mine.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
GEARHEAD
OLDIRON69 That pic is not mine it's borrowed from someone else but, shrouds like this are factory just a little messin around may be in order with your serpetine system. I think neonlarry is on the right track.
Since this is a temp set up, flaten out that finger guare a little, maybe replace your trimmed ran, and run it... if you run hotter than you like, then take it from there. These trucks have enough frontal area that plenty of air gets in there.
C10 Club Tennessee
WHOA!!!!!! I just saw a price for one of those. If I had known that I would have taken the one off of my burb before I traded it.
![]() I know that the 6 cyl shroud isn't really a shroud, but I guess I was asking for cosmetic reasons. I think it would look better then nothing at all.
The LuvShack Garage
Just pick this one up in a few weeks when we go to MV
![]() http://cgi.ebay.com/ebaymotors/NOS-1...01003794QQrdZ1
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#13 |
C10 Club Tennessee
That is a small block shroud. I have one of those.
Also I forgot that I have to run something on it or the fan will hit the upper hose. In the pic above I just have it bent back around the alt to get it out of the way.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 Last edited by 5150; 04-12-2007 at 06:19 PM. |
#14 |
The LuvShack Garage
OIC, yours won't work? it looks like you have the space
#15 |
C10 Club Tennessee
I had to trim about an inch off of the shroud to even get it to sit in there. Now, it's the fan scraping the inside of the shroud. Doesn't seem to matter which way I move it.
#16 |
Neat fan shroud. I saw one on a 67 @ the wreckers and just had to have one. As you can see it is on my truck. Looks good and it's still GMC with a dash of the "Hot Rod" spirit.
When I bought my truck the first thing I did was power flush the cooling system @ a Mr. Lube. Then in went the new rad. This truck does not have a lick of over heating problems. If your truck has a good cooling system this fan shroud should not cause you any problems but then that is only IMHO. ![]() esll. No triming needed .... note how it is installed. you will need two rubber bumpers these can be had at the wreckers as vans used these same units. this will keep the shroud from hitting the blades as you can only moved it downward so far if you lean on it.
Tomorrow is for doing today's stuff. ![]() ************************************* This truck has just the right amount of energy for me! ![]() Author: Warren Lake .... (member) Last edited by EAST SIDE LOW LIFE; 04-12-2007 at 07:32 PM. |
