04-12-2007, 02:25 PM | #1 |
Custom Fan Setup
Posted this in my build thread, but sometimes they get buried and I just wanted to show off my completed fan shroud....mainly cuz I did it pretty inexpensively. The fans are out of a late model Merc Sable that I picked up at the local Pick N pull for a mere $20!..(I think the cashier made a little error in my favor). I then figured out the shroud in CAD and then had a buddy who has a fab shop bend and weld it up for me for about $100. I have another $100 in the controller, thermostat, and additional relay wiring harness that I got all of EBay.
So I'm into the fan setup about $220 and it turned out pretty nice in my "unbiased" opinion. I also had a good connection at 1-800-radiator and got a new 4 core for about $140....let's just hope the whole setup will keep this thing cool in our regular +100 deg days here in the summer!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread Last edited by SactoJim; 10-04-2007 at 05:22 PM. |
04-12-2007, 02:35 PM | #2 |
On the fast track to nowhere..
Re: Custom Fan Setup
Hey, that looks relly good! I bet you couldn't buy something similar for twice the price
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
04-12-2007, 02:46 PM | #3 |
May I ask why you went with this system?
R.I.P. Killer 71 10/26/07 |
04-12-2007, 02:49 PM | #4 |
That is sweet look'n!
04-12-2007, 03:07 PM | #5 |
1972 Shorty Owner
Location: Stationed in Cali , born and raised in PHX Arizona.
Man i have to admit thats probably the cleanest looking setup i have seen yet.
I am curious though ... would you be interested in having one made for me? ..hehe
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project |
04-12-2007, 03:08 PM | #6 |
Awesome dude!
Tell your buddy he does great fab work! And your part doesn't look too shabby either, I might add! |
04-12-2007, 03:32 PM | #7 |
The LuvShack Garage
Agree x3 for the last 3 posts
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
04-12-2007, 03:37 PM | #8 |
Questionable
I have heard from several people that you'll need bypass holes in your shroud to allow air to pass through the radiator while driving at highway speeds. The fans can't spin as fast as they need to, and you'll burn em up. This is just what a hear (most factory shrouds are setup this way also!)
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
04-12-2007, 04:10 PM | #9 |
I wish my electric fan setup was that pretty. I am running a 16" and a 14" without a shroud. I have trouble getting up to operating temp if it isn't above 85*. Of course I run a 160* thermostat too.
Caleb |
04-12-2007, 06:04 PM | #10 |
Shifty's right you need bypass hole or you will burn up the fans. First hand knowledge talking here
04-12-2007, 06:41 PM | #11 |
frikkin clean dude...
nice job
1986 C10 SWB 6.0/6l90e Miami...Flee it like a native |
04-12-2007, 06:49 PM | #12 |
nice work Jim , i know about the heat aswell i am just up the Hill in Auburn.here was my set up.Tony
04-12-2007, 07:33 PM | #13 |
So you guys (shifty & DUD2STUD) got me wondering about this bypass thing. I've seen the after market setups that have the little rubber flapper outlets and thought they were mainly for airflow at highway speeds (less drag). Though I haven't looked closely, I don't recall seeing factory shrouds with those relief outlets.
I could understand the potential for burning up motors if the fans were pusher's and not puller's.....just seems to me that the rush of air coming through the radiator at higher speeds would only aid in the rotation of the fans and I can't imagine there would be enough velocity to make them spin beyond their max operating RPM. Does the air coming through the radiator at highway speeds actually cause some drag on the fans? ...also, I have to think that the CFM capacity of the fans at full RPM could never amount the to type of CFM moving through the radiator at 65 mph and if set up correctly, the fans wouldn't be running at higher MPH speed anyway. I know applying common sense doesn't alway work for everything, so someone explain this to me cuz I sure don't wanna burn up anything!! ...and ORTEGAMOTOR.....nice setup........you get down here to any of the local car shows and don't they have some weekly thing up there as well? ...and thanks for the compliments all!
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread |
04-12-2007, 07:43 PM | #14 |
those do look nice..... it'll cause the fans to turn slower at highway speeds, b/c the wind will only have to go through the fans, causeing the motors to strain aginst the velocity of the wind... hope that makes sence..
04-12-2007, 07:58 PM | #15 |
I guess that makes some sense. I should be OK here because the Spal fan controller will be preset at a low temp of around 175 or so and when the engine reaches that temp the fan will kick on a 50% and start to ramp up to 100% as (if) temp continues to rise. At 100%, the preset high temp point (say 195) will cause the second fan to come on at 100%.
Both fans will typically only be running in stop & go situations, so at highway speeds, the other fan will be off and provide a bypass. Does that make sense?
04-12-2007, 08:04 PM | #16 |
yea, in that instant then you should be fine...
04-12-2007, 08:46 PM | #17 |
Project Junkie! Fishing Poor!!
Here is the one that we sell and have in the Garden Truck..
Here is the same set up in pollished stainless steel... WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
04-12-2007, 09:35 PM | #18 |
hey SactoJim ... do you have a part number for the Spal fan controller?
I am running a twin fan setup and want to do exactly what you describe as far as 1 fan running and then the second fan coming on at a given temp. thanks! |
04-12-2007, 10:51 PM | #19 |
Dakota digital dual fan controller:
http://www.dakotadigital.com/index.c...prod/prd43.htm DCC: http://www.dccontrol.com/fancontrol.htm Spal controller: http://www.customstreetdesigns.com/4062-FAN-PWM.htm
04-12-2007, 11:01 PM | #20 |
Sweet
04-13-2007, 05:45 AM | #21 |
I had hot running temps until I cut a series of 2.5 inch holes in my shroud. I am running a single 16" fan. Couldn't get it to cool off at all even running down the highway.
04-13-2007, 10:51 AM | #22 |
Parts and more parts
The shrouds that SPAL sells with their dual electric fans has openings along the top and bottom that have rubber flaps over them. This is to let air bypass at high speeds and the fans do not have to run. The flaps keep the recirculation of air to a minimum when the fans are running.
I have one of the SPAL fan controllers on one of my electric fan setups and would like to get another. Where did you find the one tha tyou have for the price you mentioned? |
04-13-2007, 12:01 PM | #23 |
piecesparts
I picked up the controller on Ebay for around $75 delivered and the secondary fan relay kit for $25. You shouldn't have to buy another controller to operate a second fan. The controller I have has the ability to kick on a second fan. You will need a relay for the second fan (the relay in the controller won't handle 2 fans) and the fan speed will only be high (not variable like the first fan).
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - My Build Thread Last edited by SactoJim; 04-13-2007 at 12:17 PM. |
04-13-2007, 12:53 PM | #24 |
That is a sweet looking setup Jim. Keep us posted on how this thing works out. If it does, I'm with JHart that maybe you oughta build some of these and sell 'em.
04-13-2007, 01:12 PM | #25 |
I have seen several shrouds/fan sets sold now that do have holes in the shoruds.
