04-12-2007, 03:44 PM | #1 |
Bad Coil
My 71 with a 350 crate has been pis*y about starting the last month or so. Changed the plugs, leaned out the Holley, made sure the choke was working- all the usual suspects.
Sometimes it would just get a bug in its bonnet and decide not to start. I'd fiddle with wires, check stuff, and go through the motions and it would start up. I just figured it wanted attention. On Monday, after a 1-2 mile drive from work, I parked it in my garage. A moment later I needed to move the truck, and it wouldn;t fire. Quickly figured out there was no spark. Thinking my HEI wasn't getting enough juice, I cleaned up my circuit by wiring directly into the fuse box- that didn;t help. I decided I would put in the correct plugs for my Vortec heads (my bad- I ordered plugs without thinking I didn;t have stock '71 heads) Those non Vortec plugs were a sooty mess after only about 75 miles. Obviosuly that didn;t help. In the midst of getting that &^%& #3 plug out from behind my header, I dropped a sizable piece of road crud into my eye. No manner of flushing, rinsing or cussing would work it loose. it took a trip to the minor emergency clinic to get it out... and a tetenus shot. Maybe I should think about taking those safety glasses out of my tool chest next time... Pulled the cap on my MSD dizzy. It was a mess. Contacts were very pitted. I pulled the coil and checked the coil. I *think* the ohm meter gauge was telling me the coil was "open"- but I'm not really sure. My manual was kind of vague on the subject. I think the PO put a stock coil with the MSD module. So- I hung a new coil/cap/rotor on, turned the key and it fired instant. My question- do coils really ever go bad? I've never had to replace one on the kazillion internal combustion engines I have owned. My understanding is that they are rock-simple. What could go wrong? I read a thread and someone stated an MSD module could fry a stock coil, but they didn't elaborate. Have ya'll heard anything like this? These are the things that I think may have contributed: Accel plugs with a too-short reach for vortec heads a seriously pitted dizzy cap (motor has few miles) msd module with a stock coil What do ya'll think. Did the coil really fix it or was it more a matter of just giving "Bess" undivided attention for a couple of hours that made her spark? (I haven't washed her in a week or so) Thanks Folks |
04-12-2007, 04:00 PM | #2 |
Re: Bad Coil
Yes they can go bad, I've had a couple that did. It's an electrical component, life expectancy is from 10 sec to 50 years. Thats why there is no returns on electric components.
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again) 2002 Tarus (my wife loves that car) Last edited by bobthecop; 04-12-2007 at 04:01 PM. |
04-12-2007, 04:08 PM | #3 |
The Older Generation
Re: Bad Coil
I had a coil go bad on a '47 Chevy truck I owned once. Driving down the road and it was like you just turned the key off.... LockDoc
04-12-2007, 04:09 PM | #4 |
Re: Bad Coil
Having that happen sure sends you on a long search to narrow it down.
Happiness is towing your "new" truck home. 1972 C-10 1982 GMC (parts truck??) 1969 c10 parts truck 1969 C-10 ( my sons) 1992 Silverado 4X4 (now the boys truck)(now mine again) 2002 Tarus (my wife loves that car) |
04-12-2007, 10:28 PM | #5 |
Re: Bad Coil
Well- I spoke too soon. Just went to start the truck and it just spun. No fire. I'm okay getting juice to the HEI. I have 12.4 volts to the connector. Before I start thinking about a bad MSD ignition module, is there a smarter solution? Do I have a ground problem on my truck?
I think all of my straps are intact- 2 straps engine to cab, 1 strap cab to chassis. How should i be grounding my engine to frame? |
04-13-2007, 06:05 AM | #6 |
Black 72 Chevy
Re: Bad Coil
CCD3
Its seems that you have an intermittent module or trigger in your distributor. A.P.
72 Chevy, SWB, 350engine, TH400 |
04-13-2007, 08:46 AM | #7 |
Re: Bad Coil
i read that your wired to the fuse box did u use the yellow wire oringaly? if so the yellow wire only delivers 9 volts and and will burn an hei coil up
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-13-2007, 09:34 AM | #8 |
Re: Bad Coil
I'm leaning towards thinking it is my module.. it was my original hunch. I 'm not using the yellow wire. I bit the bullet and installed an MH engine harness for HEI and did away with it.
here's what I don't get- when it runs, it runs perfect... not a miss from idle to WOT. I thought maybe a faulty module would give a little degradation in performance or at least give me a warning hic-up or something. Does anyone know how to put a meter on the module? I'd rather check it than hang a part.. I already bought a coil I don't think I really needed. My next step is to make absolutely sure it's not a ground-issue. I'll strap the engine to the chassis really good and check. If that doesn't work, I'll alligator clip a ground from the ground clip on the distributor and put it to the frame to check. If ground checks out, I guess I'll an el cheapo module from O'Reily for testing. They have a $17 job that will work as a tester. I just don;t want to shell out $90 for an MSD module if it is something else. All this makes me wish I was a mechanic, and not a parts-hanger. |
04-14-2007, 05:28 AM | #9 |
Black 72 Chevy
Re: Bad Coil
CCD3
I few years a go I was having problems with my car's distributor. I checked the coil and that was O.k. then I removed the module and took it to autozone. They tested it and it passed. Thats when the guy told me that the trigger in the distributor was bad. I ended up replacing the entire distributor. Take your module to your local auto parts and see it they can test it. A.P.
04-14-2007, 02:48 PM | #10 |
Re: Bad Coil
Thanks for the info. When I asked my Autozone if they could test my ignition module they just stared at me... I htink maybe the manager drooled a little.
I found the test spec on the MSD ignition page for the module- there should be between 400-1300 ohms between the pickups. When i get a chance- I'll pull the innards out of the distributor and give it a try. Probably have to wait until next weekend- My 3 yo is having a b-day party today. Wife gae me "the look' when i said "I just want to try one thing..." Thanks for your help |
