Need help ASAP!! Tonight! Must get truck running!
Please help me! I have to have the truck running by 6:30 A.M., But I have to stop working on it within 1 hour (I have neighbors)
Bought a crappy j-yard dizzy that makes noise, but runs. Bought a new Procomp from ebay (at board suggestion) to remedy noise. Got the truck and dizzy dialed in, but the truck won't stay running!! I can get it to start and keep my foot on the gas and it will run, but the minute I let off it dies. If I turn the dizzy counterclockwise it won't start(sounds choppy and won't kick over) if I turn it clockwise it won't kick over (sounds like it wants to but won't. Right in between those two spots it will run as long as I have my foot on the gas and don't let off. Please help! Any suggestions would be appreciated! SHawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Re: Need help ASAP!! Tonight! Must get truck running!
First thing i would check, is to make sure it isn't 180 out.
it seems, no matter how careful i am i always end up backwards...
2003 GMC Sierra 1500 WT 1995 Nissan Hardbody 2016 Hyundai Veloster Turbo DC2 (SW/AW) Clyde W. Harvey USN "Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill |
Java Mechanic
Make sure all of your connections are clean and tight and the vacuum signal is correct.
Keith 11 Lincoln MKT -- Momma's wagon ![]() 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
its all about the +6 inches
double check the firing order... #7 and #5 are real easy to cross, and it'll still run wired as so.
did you run a "new" 12 volt switched wire to the HEI dizzy? i assume that you put HEI in if it's a new procomp? If you used the original points dizzy hot wire then it's a wire that only puts out 6 volts. Bypass it all together (cap it off) and run a new ignition hot 12 volt wire.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
GEARHEAD
All real good sugestions 18436572 and if it sounds good just not staying running just try and bump the idel up alittle till you can put a timing light on it. VERY small movements can change alot on timing so just a small amount will sometimes get ya there with out a timing light. OLD SCHOOL tighten down the dizzy so you can move it real hard by hand but not move when running and take a ride. Adjust every so often so it runs good on the road test.
Found It!!! It was a vacuum leak. The vacuum port on the back of the carb was leaking. The plug cracked and fell off and I didn't see it. I don't have a brake booster so It was plugged. Thanks for the help! Especially thanks to 67rs/ss for the phone support! You nailed it! Thanks for being persistent in making me look for the vacuum leak! Thanks for everything everyone!
Shawn
nice to hear you found it, i hate when its those little things that you forget about or overlook
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
#9 | |
Texas Big Wig
Over looking the obviouse can bite you in the rear pretty majorly, and it's happened to me more than once... that's why i normally look to what was worked on last, along with a general looking over before jumping into something big.
