350+dual flows= fun :)
ENGINE swap problemo's
after pulling the 350 4boltmain, out of my 75 longbed, to put it in my 75 GMC shortbed.
1) the speedo cable connected to the pedal and going through the firewall, seems to be way to long for the different engine... ill be taking some pic's today..... "might just need different bracket bolted to intake manifold?" 2) it doesnt look like the "chevy" 350 out of my lonbed, and the GMC exhaust will match the "chevy" manifolds...possibly.... does anyone know if the match?....its all GM from 1975 so i cant imagine why they would be different...will take pic's today ![]() 3) oil pressure sending tube is different.....i need to do some rigging, line coming out of the firewall way to short.. random question: 1) does anyone make a wing window delete? "one window" ![]()
ALWAYS CHECK YOURE FRONT WHEEL BEARINGS!! SPINNING OUT ON THE FREEWAY DUE TO THE BEARING GOING OUT IS PRETTY HAIRY!!! Last edited by 75shortysocal; 04-13-2007 at 09:11 AM. Reason: Wanted to buy posts are for subscribing members only. |
![]() Join Date: Dec 2006
Re: ENGINE swap problemo's
Send those pictures.I don't see why this wouldn't be a slam-dunk.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent. |
#3 | |
heres a better look...at the exhaust, i dont think they will match my manifolds.. ![]()
ALWAYS CHECK YOURE FRONT WHEEL BEARINGS!! SPINNING OUT ON THE FREEWAY DUE TO THE BEARING GOING OUT IS PRETTY HAIRY!!! |
Chris
OK I'm lost, I know you are taking the motor from one and putting it in another truck.
What did the truck you are putting the motor in have in it before? Was it or are they both gas motors? The exhaust looks like every other manifold setup I've ever seen, only difference maybe in the manifolds, but I'm not sure. if so then the engine you pulled from the truck if it's manifolds won't fit the one it's going into, then what happen to the manfiolds from the truck the motor is going in? Oil tube? you mean the sending unit? Did the truck the motor is going in have a motor? If so it be alot easier because you could try the original stuff and try the stuff from the new motor going in it. gmc manifolds and chevy are the same, only difference would be if you had a buick, pontiac, or olds 350 in the other truck. Speedo cable? You mean the throttle cable that hooks to the carb? if so then maybe the truck had a straight 6. Ours was like that, going from a 76 straight 6 truck with a 300 series 6 cylinder to a 350 v8 it was way too long. if it's a speedo cable that goes to the transmission and works the speedo in dash I have no idea why it be longer? There are 2 locations for oil sending units, ones above the filter, and the other behind the intake, some have big bulbs back there or just a sending unit the tube hooks to. I'd just buy an aftermarket guage for about $10-20 and it comes with line, fittings guage and all. Then just mount it under the dash or wherever. I've had them under the dash and also made a plate and removed the vent above the heater controls and put in 2 guages there. Yes they are called one piece window kits. There's a thing here about group purchase for them, and captkaos had a link on his site for them also.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 Last edited by benoit454; 04-13-2007 at 12:07 PM. |
sorry for the lack of info, i woke up at like 3:30 am and when posting this i was almost completely out of it..lol
the 75 GMC had a 350 in it.....the 75 chevy had a 350 as well...here is the exhast from the 350 engine i took out of the chevy ![]() and here is the "y" pipe that is on the GMC......im not sure if they are the same. ![]() and here is the throttle cable...seems to long for this engine? is this normal legnth of these? ![]() and the oil pressure line im talking about is the one that comes out from the firewall, and connects to the block just behined the intake, near the distributor....its way to short....i guess ill have to rig something to extend the line.....
ALWAYS CHECK YOURE FRONT WHEEL BEARINGS!! SPINNING OUT ON THE FREEWAY DUE TO THE BEARING GOING OUT IS PRETTY HAIRY!!! Last edited by 75shortysocal; 04-13-2007 at 01:02 PM. |
#6 | |
As for the oil pressure line you should be able to get some more tubing and a couple of compression fittings to make it reach. Last edited by neverfinished; 04-13-2007 at 03:54 PM. |
Insert Witty Text Here
I don't think the new engine is a '75 model. I am not sure, but I think a '75 350 would have the dipstick on the driver's side.
There is no way to tell if the manifolds will match up to the exhaust other than to look at the manifolds and see if they are the same on both trucks. if they are, it will work. If they are not, it won't. If they are not, and both engines have passenger side dipsticks, use the old manifolds on the new engine. If they have dipsticks o two different sides, I don't thing the manifolds are interchangeable. Slonaker |
Looking at the pics again I just remembered an issue we had when swapping motor in my brother's '74. The flange isn't different, I think there is a ring that sits down into the flange. The rings may be stuck in the exhaust manifolds. Just pop them out and the exhaust should fit up. We had to pop the ring out of one side when we did our swap. The first picture is the pipes without the ring and the second picture is the pipe with the ring sitting in them. If the exhaust isn't fitting together try looking into the exhaust manifold and see if the rings are stuck in there.
If the manifolds and exhaust system are different, just use the manifolds that go with the exhaust system you want to use. Thats what I would do anyway.
Don't count on that fact that it's all 1975 parts you are dealing with. Unless you've owned the trucks from day one or they have very well documented histories, quite a few years have passed where previous owners could have tampered with these trucks and that is often the case. |
glamoros piece o' lowlife
My throttle cable solution:
![]() I pulled the cable off the housing and cut the housing so only the part that goes through the firewall remains, then I ran the cable through it and left it exposed - the only restriction in cable's movement is the tiny friction due to the firewall guide, which ain't really nothing. Cable works awesome, just make sure you leave a little slack in it when adjusting it at closed throttle.
The more I drink, the more I drink, the more I drink... diesel, reg cab, long bed, 4 across the rear, single stack, wooden stakes, and lotsa lights - the Hay Express |
Flat Black, & Chrome!
Dang finally done? looks great!
#13 |
Dark Heart Motorsports
that motor does things to me, that only a woman should be able to...*shivers*
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
#14 |
You want it there when???
You have to watch so of these trucks came with manifolds that don't require donut gaskets on them. I have an 86 Silverado has older model 350 manifolds thd they don't use donut gaskets
1986 Silverado Flatbed 400 SB with 350 turbo 1997 Ford Explorer with 302 mydrive to work ride 1978 Gmc Midas RV 21ft with 46,000 actual miles 2003 Chevy Avalanche 5.3 327 and Tweety Bird Yellow Big Sandy Survivor 09 Trucks in the Blue Grass Survivor 09 TNCTC Streetcruzin |
