09-07-2002, 07:43 AM | #1 |
Truck Nut
Is the year of the axle stamped on the ring or pinion?
its hard to order parts when you don't know the year.
'70 3/4 manual w/350 4.56's .Doing a ground up on a '67 4x4 4"lift. |
09-08-2002, 09:06 PM | #2 |
Some gear sets have a date code on them, and the ID code stamped on the pass side axle tube, on the top, between 4 an 8 inches from the cast section, should identify what year it is.
09-08-2002, 09:23 PM | #3 |
Most rings have a machining date on them. Pinions probably do too, but never had one out. The date on the ring is an approxomite date of axle assembly.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
