04-13-2007, 10:18 AM | #1 |
Factory Skid Plates
Were skid plates only offered on Blazers & Jimmys as a set(t-case/gas tank)?Or,was the t-case skid plate available for the pickups?
And,these were "factory" options listed on the VIN-spec sheets,right?
04-13-2007, 05:05 PM | #2 |
Re: Factory Skid Plates
I have a Blazer with both and it just says "Skid plate" on the option list. You must have got both with a Blazer or Jimmy???
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
04-13-2007, 07:08 PM | #3 |
Not a bad nut after all..
I see it listed as an option in my Blazer GM Restoration pack (NA4), but not in my pickup GM Restoration pack.
Good question! TTT!
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
04-14-2007, 07:13 AM | #4 |
I`ll have to check the parts book.The question came up and I honestly don`t know the word on this.Joe,that`s what I`ve seen,"skid-plate".They didn`t get all wordy on those sheets,but...I believe on a K/5 it was the package,that`s one question.The pther is,did the t-case come on a pickup?I have seen a Suburban with the skid-plate option.I don`t know if there was a t-case plate.I`d assume it did originally.
04-14-2007, 08:08 PM | #5 |
ttt
04-14-2007, 08:36 PM | #6 |
Thanks for asking for me Tim,I am a little too lazy to myself
04-14-2007, 10:09 PM | #7 |
Born Psycho
i have only seen them factory equipped on blazers---i'm not saying pickups didn't get them from the factory but i've never seen one. the only one i've seen on a pickup was aftermarket--not on the build sheet and it didn't use a second crossmember like the factory version. i know this doesn't answer the question but just my 2cents.
jerry moss 72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD 69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies. 73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog. 77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW BRENTWOOD,CALIFORNIA |
04-15-2007, 04:27 AM | #8 |
Yeah,I`ve never seen one on a pickup.I haven`t seen them all....yet.I`ve bought them from Cepek in the past.I definately saw the option on a`71 K/20 Suburban.
Dustin,I just had to ask.
04-15-2007, 10:52 AM | #9 |
The skid plate is only listed for Blazers in`71 dealer order book.They are listed as "Plate" for gas tank,the t-case just comes along.I know I saw "Skid-Plate" listed on this Suburban I looked at.It was real loaded,but too rusty...a shame.
04-15-2007, 11:04 AM | #10 |
Born Psycho
i have one factory unit and a fellow board member made duplicates of the plate itself but you need the rear crossmember. turns out the rear crossmember is the same as the one used on 67-69 longbed 4x4s under the carrier bearing. he made me 4 or five of the plates and i've gathered a few of the correct crossmembers for the rear. the plates he made are exact duplicates of the original--without 30+ years of grease, dirt,etc.
04-15-2007, 11:08 AM | #11 |
anybody have a pic of these?
04-15-2007, 11:15 AM | #12 |
I always thought the rear skidplate crossmember looked like the t case crossmember.Did the second crossmember,for the skidplate,have only a lower portion to mount to the frame?Or did it have a upper portion too,like the t case crossmember?Here is what I have,from a 72 CST K5 supposively.Is it all there?I had no clue how rare it was,I knew they werent plentiful,but just got this cheap.I got a np205,TH350,t case skidplate,both crossmembers,for $150
Gator,here is a pic: Last edited by 1969k10stepside; 04-15-2007 at 11:17 AM. |
04-15-2007, 11:19 AM | #13 |
Born Psycho
the skid plate rear crossmember only uses the lower portion not the upper side pieces
04-15-2007, 11:20 AM | #14 |
Thanks for the info Jerry,I think instead of selling I will keep the skidplate and mount it on the shortbed 4x4.I'm so proud I think I will go mount it right now...lol
04-21-2007, 07:47 AM | #15 |
My 68 had a smaller skid plate that was attached to the lower crossmember in this pic. I'll get pics later...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
04-21-2007, 08:36 AM | #16 |
Does your truck have it listed as an option?I have one left that I bought Dick Cepek.It`s about 12" wide and has a "kick-up" at the front.There`s a hole in the bottom to access the one t-case mounting bolt.It`s a much nicer piece than the factory one.I also have a gas tank skid-plate that was mounted on the`72 Blazer I have.I believe it`s aftermarket,too.
04-21-2007, 09:02 AM | #17 |
shoot some pics when able... I'll have to check the glovebox and get pics of mine today. I need to do a little metal repair on the crossmember too, rust ate at it....
04-21-2007, 10:52 AM | #18 |
My old 69 has the same skidplate as Msgross.Its the one under the carrier bearing crossmember.Its not listed as a option
10-10-2008, 12:27 PM | #19 | |
Glen |
10-10-2008, 04:11 PM | #20 |
Post Whore
Here is what is under my 69 K20's carrier bearing crossmember
Nothing listed on my glove box sticker.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
10-10-2008, 10:28 PM | #21 |
my black 72 has one as spec k described with a angle and a hole in it, nothing listed on glovebox although who knows how many gloveboxes the truck has had, although the skid plate looks factory as can be. ill try and get a pic to add.actually found one in a junkyard picked it up off the ground and sit it against a tree .maybe will have to go back and get it, but with the price of scrap metal .
1969 rs 1966fastback 1969swbc/10 2006gt 1972swb4x4 |
10-11-2008, 12:53 AM | #22 |
My new one came with the rare corvette skid plate.
1972 3/4T 4x4 Chevrolet (383) 1971 c-10 SWB (400 sb) 1972 4x4 Blazer 1969 SWB 4x4 GMC Projects: 1972 stepside 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=280132 http://67-72chevytrucks.com/vboard/s...d.php?t=285952 http://67-72chevytrucks.com/vboard/s...d.php?t=553672 http://67-72chevytrucks.com/vboard/s...d.php?t=522704 |
10-11-2008, 08:59 AM | #23 |
Just realized I never posted pics of mine...
I don't think it's on the option sheet but it had this smaller skid plate under the TC. And yes it's the same crossmember as the tanny without the upper braces.
10-11-2008, 09:09 AM | #24 |
Active Member
Jerry Moss: Do you have any of the duplicate skid plates left, and if so are they for sale?
10-11-2008, 06:49 PM | #25 |
heres a pic of mine, sure looks factory enuff, but is not listed on g/b, im sure it will be for sale if i have to remove it again.
