04-13-2007, 05:06 PM | #1 |
tried search, no luck- looking for 2.5-4 inch drop pics
wonderin if anyone had pics of 2. front and 4 inch rear drop pics. i tried searching but didnt get much luck this is the drop im probably gonna go with, but i wouldnt mind some pictures to check it out. thanks
87 chev wrangler |
04-13-2007, 05:25 PM | #2 |
Re: tried search, no luck- looking for 2.5-4 inch drop pics
heres my 3/5
1985 C10 SWB- *Project* |
04-13-2007, 05:36 PM | #3 |
WTB this ad
Slonaker has some pics of his 2.5" 4" drop. Do a search for his posts or send him a PM.
04-13-2007, 06:00 PM | #4 |
Insert Witty Text Here
The only pic I have of it at 2.5/4 on my website is this one:
You can see a larger verion here: http://www.slonaker.net/gallery/albu...cs/c10_low.jpg Wait...this is a before/after shot with it at 2.5/0 and 2.5/4: http://www.slonaker.net/gallery/albu...fore-after.jpg I have more, but they aren't on the site. Slonaker |
04-13-2007, 07:01 PM | #5 |
>130dB Moderator
Tell me what angles you want and I'll go take the pics of my truck.
04-13-2007, 08:54 PM | #6 |
how about a front, side and rear shot. that would be awsome
87 chev wrangler |
04-13-2007, 09:04 PM | #7 |
>130dB Moderator
Be back in a few...
EDIT: Back w/ pics... EDIT2: Tires sizes; 255/60/15 Front 275/60/15 Rear Last edited by AceX; 04-17-2007 at 04:24 AM. Reason: pics added; tire specs added |
04-13-2007, 09:36 PM | #8 |
awsome, thanks for the pics. cant wait to order my kit now
87 chev wrangler |
04-13-2007, 09:40 PM | #9 |
>130dB Moderator
Just an FYI;
I have a Belltech kit. Front came by way of drop spindles and rear was done with a set of shackles and hangers. Only cutting involved was a small notch right above the shackles in the very rear. An easy task with a cutting wheel and an air compressor. Hardest part will be removing the rivets on the hangers... EDIT: Also, I reccomend getting new shocks and also checking tire clearances. My fronts rub and the wheels arches cut into the tires. I was running the same tires all around until I lowered it and this became a problem. It's still a small issue, but not as big as it was when I was running a 275 series tire up front. If you don't have new rims yet, make sure to check and double check your back spacing and tire clearances before buying them. Last edited by AceX; 04-13-2007 at 09:43 PM. |
04-13-2007, 11:43 PM | #10 |
Mine uses spindles with new, stock coils on the front and and drop leaves on the rear. Tires are 255/70/15 Radial TAs all the way around, on 8" rally wheels. Nothing scrapes, even at full left or right lock.
Slonaker |
04-14-2007, 12:23 AM | #11 |
Spear and magic helmet!
AceX, that's a nice truck, dude. Love those wheels. Is this the first time you've posted pics?
Sorry to threadjack, munroe.
-- Will |
04-14-2007, 07:53 AM | #12 |
AceX, Are those wheels 10" wide or 8" wide with a shallow backspacing?
Truck looks great!
04-15-2007, 05:59 AM | #13 |
>130dB Moderator
My wheels are 15x10. My Uncle had them on the truck like a month after he got it.
I've gotta Simmichrome 'em again. The water spots are beginning to bug me. My only real beef with these wheels is that they are a uni-lug setup so whenever I wash them, water sits inside of the area around the studs and slowly drips out, or it shoots all over the wheels when I drive it... Yes, this is the first time I have posted pics of the truck. Last edited by AceX; 04-15-2007 at 06:00 AM. Reason: speeling... |
04-15-2007, 05:51 PM | #14 |
thanks for the info AceX, those are also the same size whels in planning on running. looks like you killed two birds with one stone for me
87 chev wrangler |
04-15-2007, 06:46 PM | #15 |
>130dB Moderator
Make sure you get the right offset on the front wheels or you may have problems with the tires rubbing. The rears I wouldn't worry as much...
04-15-2007, 06:51 PM | #16 |
Chris
When you say unilug you mean they have more then 5 hles drilled in them or they just have oval holes where the lug nuts go?
If they are oval holes then you are not using the right washers or maybe lug nuts. I have a set of cragers that are unilug, they have an oblong/oval slot for the lug nuts, they fit 5x4.5 5x4.75 and 5x5 bolt patterns, and thus you must use a thicker center hole washer for the 5x4.75 or in your case the offset ones, they are thick on one side and thin on the other just for the offset so they cover the holes. Usually on unilugs like mine you HAVE to use thoose washers and correct lugs or they'll flop around making noises, or bounce up and down, vibrate all that kinda crap and eventually were out the lug nut holes. That was a pretty common deal with the oblong hole unilugs. I would think running the smallest or in your case largest bolt pattern would lessen the chances of that since they'll stay in contact with the rim. You just need the washers to cover the holes. I have some I can take pics of if you want and yours are oblong. if they have more then 5 bolt holes I can't help ya, doesn't look like they do though. You can get the washers from summit racing, jegs, ebay, or maybe local parts stores or tire/wheel place. I got mine from summit, not too expensive.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
04-16-2007, 05:32 AM | #17 |
>130dB Moderator
I have washers, they don't work...
I'm just gonna have to live with it for now. I have bigger fish to fry at the moment. I just figured out that I may have a cracked head, or at least a blown head gasket... |
04-16-2007, 09:56 AM | #18 |
im going to be runnin 8 inch rallys on the front so it shouldnt rub for what ive read. im going with 4 inch back spacing on the rear 10 inch rallys.
87 chev wrangler |
04-16-2007, 01:15 PM | #19 |
>130dB Moderator
That will work just fine then.
04-16-2007, 02:32 PM | #20 |
Chris
Yes you may have washers but if they are unilug and you don't have the offset washer then they are not right.
Which means they'll do exactly what yours is doing. I'll find a pic and post it for you to compare. Hate to hear about your head, I had that scare last year on my monte carlo. I ended up tearing it down, doing a valve job and head gaskets. Ok here's a link on summit's site, if yours have the oblong holes in the wheels then you need theese washers, they should take care of the water problem on the wheels from the holes dripping. http://store.summitracing.com/partde...5&autoview=sku
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 Last edited by benoit454; 04-16-2007 at 02:36 PM. |
04-16-2007, 08:31 PM | #21 |
>130dB Moderator
Dude, I f***ing love you...
04-16-2007, 09:20 PM | #22 |
Chris
LOl no problem bro.
Glad I could help you out. heck I have some but not enough to make a full set, I got them when I had to buy the correct lug nuts for my monte carlo, they came with lugs center hole and offset washers. My cragera are the exact same oblong unilug, but without the correct center holes on my 4.75 bolt pattern they'd flop around and bug ya, since yours is big pattern the thin side would go up or outwards, and the thick side towards the center of the wheel, it will cover your holes up and should completely stop the water problems. Plus if you gotta order gaskets to fix the head problem, heck might as well order thoose then, it sucks to pay $10 shipping on $20 worth of small parts.
04-16-2007, 10:40 PM | #23 |
BAD BOW-Silverado XST
Visit my visit my website. I have installation pictures of a 2.5/4 drop for my truck.
04-17-2007, 04:16 AM | #24 |
>130dB Moderator
Turns out it wasn't the head actually. It was the water pump... I couldn't trace the leak until a few hours ago when it finaly started to drip.
04-17-2007, 12:29 PM | #25 |
Chris
Nice so that should be an easy fix and shouldn't have any problems then. That be alot better then a head gasket change.
