Old 04-13-2007, 07:26 PM   #1
76bonanza
76bonanza's Avatar
hei question
I got a factory hei pigtail I know how it connects to the dizzy but what did this other end connect to? Never seen a conector like that.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 04-13-2007, 07:31 PM   #2
corn
Re: hei question
Snip snip. Its made for a newer vehicle that had an HEI from the factory. You will have to cut the end off & depending on how you convert the wire on your fuse box will determine the wire end you use...
corn is offline   Reply With Quote
Old 04-13-2007, 07:34 PM   #3
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: hei question
hey pink
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 04-13-2007, 07:35 PM   #4
john
member #16
john's Avatar
Re: hei question
If the wire is long enough it will plug in the firewall block where the resister wire is now. Looks like the same terminal end.
john is offline   Reply With Quote
Old 04-13-2007, 07:39 PM   #5
76bonanza
76bonanza's Avatar
Re: hei question
I think now it is pluged into the fuse block on the ING with a female spade.
1968 c10
lowered 3" 4"
