Old 09-07-2002, 12:25 PM   #1
Orence1
Orence1's Avatar
Help! Anybody got an extra one of these?
I need this special bolt. It goes through the bottom hole in an alternator on a BB with a long water pump. Large end with the nut screws into the head and small end goes through the lower bracket with a nut to tighten it up. Can not only not find one around here but nobody seems to know what I am talking about. If you have one and are willing to sell it, please let me know.
Thanks,
Larry
Orence1 is offline   Reply With Quote
Old 09-07-2002, 04:01 PM   #2
68C10
Looks like a dealer item to me. I have seen a similar bolt on I-6's that is used to brace the power steering pump.
68C10
1968 C10 SWB No Options but 40K original miles
1967 K20 LWB 283 4-speed
South Plainfield, NJ
68C10 is offline   Reply With Quote
Old 09-07-2002, 04:35 PM   #3
Gene
Gene's Avatar
Looks like a standard 3/8 rod with threads on both ends and a nut threaded on? If you cannot find one, take your dimensions to a machine shop and they can whip you one out for around 20 bucks, they can thread as much as you need on both ends, I have had to have this done before on wierd bolts.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 09-07-2002, 04:56 PM   #4
Orence1
Orence1's Avatar
Have checked with the dealer and it was discontinued in 1992. I will get it made if necessary but am still hoping that one of you guys has one laying around.
Larry
Old 09-07-2002, 05:34 PM   #5
Capitol68
Capitol68's Avatar
Hey there,
Yea it is special from what i can see. Looks like it was made from a piece of hex stock( ie. nut shape ). And with a 3/8-16 on short end with 3/8-24 on the other. Or 5/16-18 and 5/16-24 , hard to tell with no references. Questions or comments u can PM me.
Mark
'68 Fleet LWB
orig 307 .030 over
GM Hei/w Accel Super coil
orig. stock TH 400.
_______________________
“What we do for ourselves dies with us. What we do for others and the world remains and is immortal.”
Albert Pine
English author d.1851
Capitol68 is offline   Reply With Quote
Old 09-07-2002, 05:39 PM   #6
slam33
slam33's Avatar
check a local hardware store that carrys studs like Dorman. You should be able to find one that works
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 09-07-2002, 05:41 PM   #7
Capitol68
Capitol68's Avatar
ps
it is not rod with a nut screwed on, if u look at picture the nut end the threads do not go all the way to the nut. Hence hex stock.
If u have to have one made take a pic to the shop and a screw that u know goes in the head. The other end can be what ever u want.
later
'68 Fleet LWB
orig 307 .030 over
orig. stock TH 400.
Albert Pine
Old 09-07-2002, 11:41 PM   #8
Orence1
Orence1's Avatar
What I didn't mention is that one end (engine head end) is one size larger than the other end which tightens the alternator to the lower bracket. One of the things that I am learning is that a lot of these odd parts for our trucks are just not very available any more. I have learned that this part is probably for a BB with a long water pump. I did do some junk yard hopping today. One place had no clue and the other would sell me one as long as I bought the brackets and pulleys for $150! Hope one of you guys can help me out.
Larry
Old 09-08-2002, 06:42 PM   #9
Fast68Chevy
Fast68Chevy's Avatar
would one on a 72 trruck 402 be the same ? its short pump setup, i removed brackets off one such engine and dont remember whewre hardware went, its probably tossed who kows where around this building by now.
email me length from the backside of the hex, to the end of the stud(long end)
is it 3/8 diameter mainly and short end 7/16" or vice versa ?
fastr68@yahoo.com
thanks
Fast68Chevy is offline   Reply With Quote
Old 09-08-2002, 06:47 PM   #10
mikep
Used to have a truck
mikep's Avatar
here is a slightly enhanced copy of your picture for better detail on the threads.
Having worked in machine shops before I'd have to say that having a one off made is going to cost more than $20 for that sort of piece/ The problem being the hex head. They could cut it out of hex stock but the heat treating necessary after machining that deep is going to cost you. a better option migh be to bore a short 7/16" bolt and tap it 3/8 coarse and screw a long 3/8 stud into it with permanent loctite. That way you could use a decent grade of bolts instead of the crap that usually passes for hex stock.
I'd be willing to make one for you on the lathe if you cant find another if you want to send me a piece of hex stock and pay for shipping.
No truck :-(
mikep is offline   Reply With Quote
Old 09-08-2002, 07:10 PM   #11
Fast68Chevy
damn, thats a good enhancement there!
7/16" short end and 3/8" long end, i can see that plain as day now lol! nice!
ill see if i can dig up the one i remoced from the 402, i have no idea how spoon that coud be, maybe tonight or maybe in an hour, dunno, am cutting up truck chassis right now and scrapping parts
Old 09-08-2002, 07:25 PM   #12
mikep
mikep's Avatar
If Fast68chevy cant find one I have a whole pot full of thread repair sleeves that you can use to make a stud out of. Theyr'e kind of like helicoils except they dont suck. Its just a threaded sleeve with 7/16 thread on the outside and 3/8 threads on the inside. All you'd have to do is screw one onto a much easier to find 3/8" threaded stud and then tighten a nut onto it to lock it in place. Pay the shipping or just drive over from Seattle and its yours. Once installed you'd never know the difference. Heres a pic of one using a bolt just to give you an idea of what I am talking about. I use those thread repair sleeves for a lot of stuff the makers never intended.
No truck :-(
