04-27-2002, 10:13 AM | #1 |
installing upper control arm
Here's another example of why you should take notes. Getting ready to install the upper control arm and I can't remember exactly where the convex spacer goes(looks like a thick washer dished on one side). Does it go behind the shim pack or between the shim pack and cross shaft.Thanks..Stroker
72 SWB parts and pieces Oklahoma |
04-27-2002, 01:31 PM | #2 |
goes shaft shims then the spacer
[This message has been edited by VC57Bowtie (edited April 27, 2002).] |
04-27-2002, 02:01 PM | #3 |
spacer goes back behind shim packs, closer to engine than the shim pack, i just glanced at the 71 to make sure, front clip is removed currently, if you need any details or measurements or anything at all lemme know i can measure on the 71, its stock and original and unmodified
------------------ Randy- Lincoln, IL r68c30@hotmail.com 2177353230 -71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not) -84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,, -84 Firebird SE 2.8L T-5, rod knocking, dammit,, -82 Firebird 350 4bolt (TBL)/TH350, not running, dammit... buy/sell/hoard/trade most any GM vehicle parts of any kind -parting out: '81 Cutlass Supreme Brougham *Paint is overrated © RSS Enterprises 2000 [This message has been edited by Fast68Chevy (edited April 27, 2002).] |
04-27-2002, 03:31 PM | #4 |
Thanks for the info guys.Anyone got any pointers for installing the front springs on a bare frame.I don't think there will be enough weight without a engine or body to use a jack to compress the spring.I'm guessing a spring compressor will be needed....Stroker
04-27-2002, 03:40 PM | #5 |
stroker,i had the same problem with spring,i bolted a piece of angle iron on the concrete floor. next to each side of frame then put a 4x4 across frame with chain down to each angle iron,then used floor jack under lower A arm.sounds like alot of work,but worked slick for me.
Springvale,Maine 71 3/4 GMC lwb |
