![]() Join Date: Sep 2006
wtk
can anybody tell me on a 73-87 big block truck are the mounts on the frame the same as a small block
dang its hot
Re: wtk
I took a 305 out and bolted in a 454 with no problems. The motor came out of a suburban and I think I left the suburban mounts on the motor. I've done this swap on cars before with no modifications.
Re: wtk
what i have is a 72 truck with a 350 putting in a 454 i thought i might be able to use the better mounts on a 73-87 truck wonder if the frame engine mount on a the 73-87 are the same on 350- 454
dang its hot
Re: wtk
as far as a 72 model, I don't know if the frame mounts interchange but I know if you put the existing 350 mounts on the 454, it will bolt up
Keepin an eye out
Re: wtk
'72 big block mounts are unique to that year, only 72 big block mounts will work.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
