Old 04-14-2007, 11:35 AM   #1
Luvlegs
Luvlegs's Avatar
fuse size instead of fusible link(s)
72 C-10 - I-6
Starting over - found an old post I'd made - geesch - memory is going!
Have 20 amp fuse instead of fusible link - truck starts - fuse blows - stays running and everything works.
Been through all the "electrical" and "shorts" posts - can't find anything similiar - Rang out all the wiring - no shorts -
Ringing to ground - red wire - when key is on - even with voltage regulator unhooked - all good at back of ignition (took it out to check even).
Any idea where to start next? Am I just under fused at 20A (fusible link was 14A)?
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 04-14-2007, 12:13 PM   #2
kbs71
71 rustless in texas
kbs71's Avatar
Re: fuse size instead of fusible link(s)
Defenition of a fusable link
"A fusible link is a protective device used in an electrical circuit and acts very much like a standard fuse. The major difference lies in that fusible links are larger and capable of conducting higher amperages than most fuses. When the current increases beyond the rated amperage for a given link, the fusible metal of the wire link will melt, thus breaking the electrical circuit and preventing further damage to any other components or wiring. Whenever a fusible link is melted because of a short circuit, correct the cause before installing a new one".
Most fusable links are 4 wire sizes smaller than the wire they are protecting. So either you don't have a big enough fuse, or the over voltage condiiton that your experencing is lasting long enough to blow the fuse, but not melt the fusable link.
What size fuse were you using?
Where in the electrical system are your fuses located?
What electrical mods have you done?
Heres a schematic for how a relayed set of headlights should be.
"The secret to creativity is knowing how to hide your sources."
"No one really listens to anyone else, and if you try it for a while you'll see why"
71 C-10 LWB presently in a perpetual state of disassembly
'96 Toyota (my work car)
'04 Mustang Convertable (wife's car & other money pit)
Latest aquesition and why my trucks still in the garage covered with junk..
2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck
FAQ here
VENDORS here
SUPPORT THE BOARD here
My second favorite SITE
kbs71 is offline   Reply With Quote
Old 04-14-2007, 12:17 PM   #3
kbs71
kbs71's Avatar
I was downloading that schematic when you updated your post. I would think you'd need a 50 amp fuse as the main power fuse. Shoot just add up the amp of all you fuses under the dash. I think they add up to a little over 60 amps.
FAQ here
VENDORS here
Old 04-14-2007, 12:26 PM   #4
kbs71
kbs71's Avatar
Heres a picture of a labeled fuse holder for our trucks. I counted @ 89 amps in the entire fuse block. I still believe 50 amps should be sufficent.
http://67-72chevytrucks.com/vboard/s...d.php?t=177316
FAQ here
VENDORS here
Old 04-14-2007, 01:41 PM   #5
Luvlegs
Luvlegs's Avatar
HOLY CAMOLEE'! I had no idea - mainly because I thought the original fusible links were only rated at 14A....? OK, now I have to relook at the relays for the headlights.... I'm 99% certain I have what's in the diagram you posted (thanks) - but, I've been mistaken before... I'll be back....
1972 C10 L6 3OTT
Old 04-14-2007, 03:11 PM   #6
neonlarry
neonlarry's Avatar
They use fusible links for a purpose. A fusible link will withstand a momentary surge in current and not burn out it takes a sustained short before they will do that. With a fuse a momentary increase in current is enough to blow it. If you put in a fuse big enough to withstand the highest momentary current you might experience it would allow too much current to protect some of you electrical components.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
