Old 04-14-2007, 01:17 PM   #1
NF65Fleetside
NF65Fleetside's Avatar
Question Need opinions....my motor setup
Hey guys, Im new to all this but recently rebuilt my motor in th 65 c-10. 350 shortblock with 283 heads, Edelbrock perf. int. mani., 4barrel carb, block hugger headers. TH350 with 2800 stall converter....is the stall too much for daily driving/a bit of fwy?...when test driving it, the fawker spun the wheels at any type of throttle pressure! fun...BUT took it on the fwy for a few and it just seems to rev like crazy! not sure if this combo is good for the highway or not.
NF65Fleetside is offline   Reply With Quote
Old 04-14-2007, 04:33 PM   #2
Jonboy
Slots go on anything!
Re: Need opinions....my motor setup
Should be fine. What gears are you running? That will be the main factor.
Old 04-14-2007, 06:17 PM   #3
NF65Fleetside
as far as I know its just the stock rear end, so whatever that is????
Old 04-14-2007, 06:48 PM   #4
desertrat
desertrat's Avatar
I'd say you have a gearing issue, torque conv. sounds like it's doing it's job.
Our trucks came with differant gear ratio's, alot of them with low gears because they where built to work.
desertrat is offline   Reply With Quote
Old 04-15-2007, 07:28 AM   #5
jwart
got 65 also rearend could be anything from 3.07 to 4.11 gearing. mine's 4.11 great for keeping tire companies in business but lousy for hwy. driving 65mph is max i run it at. had to go to 5 core radiator to do that.
jw
jwart is offline   Reply With Quote
Old 04-15-2007, 03:01 PM   #6
NF65Fleetside
thanks for the info guys.
Old 04-15-2007, 03:19 PM   #7
19GMC63
19GMC63's Avatar
you can always do the test to find out your gear ratio.
With the truck in neutral, jack up one side of the rear end.
If that tire doesn't spin, its a posi, if it does, you got an open differential.
Now jack up the whole rear end so both tires can spin freely.
Mark where the driveshaft meets the rear end so you can count how many revolutions it makes.
If you have a posi, spin a tire one full revolution while counting how many times the driveshaft spins.
If you have an open diff., spin a tire two full revolutions and count how many time the driveshaft spins.
If its a little over 4, you've got 4.11 gears, around 3 3/4, you've got 3.73, ect. ect.
19GMC63 is offline   Reply With Quote
Old 04-17-2007, 10:20 PM   #8
NF65Fleetside
hehehe, wow thats a kewl test to follow....Ill try that for sure. Thanks
Old 04-17-2007, 10:33 PM   #9
bowtieguy61
or you could just pull the diff cover and count the teeth. besides, when is the last time the diff lube was changed????
bowtieguy61 is offline   Reply With Quote
Old 04-19-2007, 05:53 PM   #10
NF65Fleetside
good point....Im change'n that next week for sure!
