3 speeds trans
i have a 1960 with 283 v8 and a 3 speed, trans looks real small to handle some more power is the 3 spped trans really tough
Hollister, CA.
![]() Join Date: Sep 2006
Re: 3 speeds trans
I'll let you know...
![]() ![]() John
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
![]() Join Date: Nov 2006
Re: 3 speeds trans
It's small because there are only 3 gears. It can handle a few more horses.
Just don't try reverse burnouts ![]() Also don't speed shift if it is still a column shifter. ( another stupid mistake a 16 yr. old makes) ![]() |
Re: 3 speeds trans
thanks for the info
Re: 3 speeds trans
The strength isn't the problem, it the fact that first gear is not synchronized. You must make a complete stop to put the transmission into first gear or you will hear a grinding sound.
Re: 3 speeds trans
is this 1st gear not syncrinized in turbo 35o's also? I know its an auto, but if i dont make a cmplete stop, the truck doesnt accelerate as well, like its in second instead of first.....(sry for the highjack)
Brad
2000 GMC Sierra EXT Cab Short 4x4, finally mine... 1966 C10 SWB Fleet, 250 I6, three on the tree.... Previously Owned.... 1987 Chevy R10 "Silverado" (at least the badges were) Short Step 350 700r4.... 1972 Chevy LWB Fleet 350/350 EXTENDED CAB ALL THE WAY! .._..~...-...._...____ .._..-...______|_|__\____ ..-..~.|_(O)__|_|__|_(O)] |
Hollister, CA.
Re: 3 speeds trans
Sounds like you have a kick-down linkage problem....disconnected or mis-adjusted.
John
![]() Join Date: Sep 2003
Re: 3 speeds trans
have 327 build 4000m. ago. 450 lift cam & 850cfm quadjet off big block buick. i bang gears pretty hard with it. got 4:11 rearend & can lay 50yrd of rubber & make it squell thru 3rd. put indy floor shift on it. even fit good with bench. has held up thru 2 sets of tires. have it going into my shop this week for front disc brakes/thanks to a 78 donor truck. drums just don't cut it anymore jw
straight pipes save lives! ![]() Last edited by jwart; 04-15-2007 at 07:08 AM. |
