Old 04-14-2007, 03:58 PM   #1
rmorelan
location of frame vin
Wheres the location on 71 c-10 of vin numbers on frame? thanks.
rmorelan is offline   Reply With Quote
Old 04-14-2007, 04:36 PM   #2
centsless
sufficiently talented fool
centsless's Avatar
Re: location of frame vin
On top of the framerail in the engine compartment. It is near the steering box.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
Old 04-14-2007, 04:40 PM   #3
rmorelan
Would that be the correct location for a 68 also?
Appreciate your help,
Randy
Old 04-14-2007, 04:43 PM   #4
70GMCer
70GMCer's Avatar
and a 70?
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-14-2007, 05:20 PM   #5
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
Wink Re: location of frame vin
my 67 has on the left frame rail just behind the steering box , AND MINE MATCH'S !!!!!!!!!
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 04-14-2007, 06:35 PM   #6
centsless
centsless's Avatar
I know it is there on a 1972 and a 1969. I am not sure about earlier ones. A GMC should be the same.
2003 Suburban
1981 Corvette
Old 04-14-2007, 06:39 PM   #7
sighlurr
______________
sighlurr's Avatar
My 67 was on the driver's side rail too.
sighlurr is offline   Reply With Quote
Old 04-14-2007, 06:46 PM   #8
rmorelan
Thanks for all the help. I have looked from the steering box to the cross member, with no luck. This truck was titled as a 68 GMC. It is six hole, drumb brake frt. and rear, with leafs. Would that make any difference, it being GMC? I have a 71 chevy C/10 lwb 2x4 that I am trying to find a good/straight frame for. It was wrecked on the passenger side front when I bought it. Was there a chevy six hole, half ton, rear leaf, drumb brake built in 71?
Old 04-14-2007, 06:55 PM   #9
centsless
centsless's Avatar
No. all of the half ton Chevy's in 71 were disc brake 5 lug. The vin should be several inches back from the steering box on top of the frame. It all fits to be a 68 GMC> That would have been a drum brake, 6 lug, and I think more likely to have leaf springs. If you want to use the frame, you can. You will have to keep the leaves, But the frame itself will fit. Use the control arms off of the 71, and the spindles, etc. You will have to weld up some stands on the leaves, though.
2003 Suburban
1981 Corvette
Old 04-14-2007, 07:01 PM   #10
72ironmike
72ironmike's Avatar
I believe there are two vin # on these trucks. There is also one underneath the cab on top of the frame? If you can lift the cab maybe you can angle a mirror to see the numbers.
72ironmike is offline   Reply With Quote
Old 04-14-2007, 07:18 PM   #11
rmorelan
I'm trying to make it as close to original or correct as possible. I'm going to keep looking for this vin. I'm sure it has to be there some where. This is just a roller no body. I do have a title. The vin # is CS10DPB13709. I haven't been able to exactly crack this one eithor. It seems to have letter where I should have numbers? I'm starting to think that it would be best to find a 71 roller and leave this one for another day.
Old 04-14-2007, 08:38 PM   #12
Ram-Man
Ram-Man's Avatar
Mine also has 2 one under the middle of the cab and one in the engine comp. where the frame humps up.
Porterbuilt 8 Lugger
http://67-72chevytrucks.com/vboard/s...d.php?t=691739
Ram-Man is offline   Reply With Quote
