Old 04-14-2007, 04:50 PM   #1
barleywilkerson
axle questions!
well, as it turns out, i have a bent rear axle... gonna have to replace it...
i've never pulled an axle before, so is there anything in particular i should know before i get in there? there's just a seal, bearing, and the axle itself, right?
do i have to mess with the differential at all?
off to search for parts and stuff... later!
and thanks, too...
barleywilkerson is offline   Reply With Quote
Old 04-14-2007, 05:24 PM   #2
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: axle questions!
If it is just a 1/2 ton 12 bolt you take the drum off, take the diffy cover off, take out the 5/16 thread bolt (1/2 head IIRC) on the spider gears, pull out the big pin that goes through the middle there, push the offending axle inward, remove the c clip, and pull the axle out.
WORD OF CAUTION: do not move the spider gears while the big pin is out!!!
Replace that $3 oil seal while you have it apart.
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-14-2007, 07:29 PM   #3
barleywilkerson
Re: axle questions!
okay... that sounds easy enough, except that it's a 10 bolt... also 6 lugs... what about gear oil? any particular kind? how much? and about how long should the whole process take?
Old 04-14-2007, 11:04 PM   #4
Bus Ted Knuckle
Son of a gun
Re: axle questions!
Yeah, I should have wrote 10 bolt...sorry bout that! Get some 90 wt gear oil and fill until it runs out the fill hole. I pulled both axles and replaced both wheel seald in about 30 minutes last weekend.
BEATERS ARE NEATER
Old 04-15-2007, 09:30 AM   #5
barleywilkerson
Re: axle questions!
you have no idea how awesome it is to know this now! as soon as i get my truck fixed right i can pick up my bike!!! YESSSSSSSSSSSS!
Old 04-18-2007, 03:47 PM   #6
barleywilkerson
Re: axle questions!
okay... just pulled my axle and it was way easier than i expected... waiting for the new one to come in tomorrow and i can put everything back together!
hopefully everything will be pretty much finished after this, and i can drive my truck again!
thanks for helping
Old 04-18-2007, 05:18 PM   #7
Srubydo1986
The Crazy Machanic
Srubydo1986's Avatar
Re: axle questions!
im still trying to figure out why you let the truck sit for so long after the crash.
*1986 Sliverado longbed 400 small block mean as hell, 700r4 trans (5 speed coming one day)
* 1970 chevelle 2dr sedan Latest update June 24 2007.
*1957 4 door stationwagon - pink all original needing a good restore (body great, floors bad)
newest additions
1965 shortbed fleet great granddads. Been told im nuts to bring it back from the dead (still going to happen) plans-all stock with a turbo 292 inline 3 speed column shift. and thats it
big block 427 and 5 speed trans and ford 9 inch theyhave no home yet thinking what to put them in
and a 79 c60 trash truck um no idea i have one
Srubydo1986 is offline   Reply With Quote
Old 04-18-2007, 08:26 PM   #8
barleywilkerson
Re: axle questions!
well... money was an issue... had some medical problems and stuff and the truck wasn't that important at the time... BUT NOW! i have a daughter coming in june and we're all supposed to moving in the very near future, so i need my own transportation so the wife can take the car...
now i just need to figure out what i want to do with my tailgate... thinking about barndoor conversion...
Old 04-18-2007, 08:33 PM   #9
Srubydo1986
The Crazy Machanic
Re: axle questions!
that sounds sweet. When someone posted about te barn door set up i started to draw a scketch in my head (still need to draw on paper). A tail gate that does barn doors and the traditonal design. (yes i know sounds a little dumb but id be the ony guy with one and it would be fun to do)
newest additions
Old 04-18-2007, 08:44 PM   #10
JESSEGALLEGOS
JESSEGALLEGOS's Avatar
Re: axle questions!
I had replaced my rear end from one from a junk yard and it happened to have bad bearings. I also have never worked on a rear end and so far it's been pretty easy.(practiced on the old one first) The only problem I have had so far is trying to find someone to press out the bearings. One of the draw backs of living in a small town. If you need any parts shot me a PM
1982 BLAZER 2WD
http://img.photobucket.com/albums/v7...t/145c37fd.jpg
JESSEGALLEGOS is offline   Reply With Quote
Old 04-19-2007, 08:41 PM   #11
barleywilkerson
Re: axle questions!
thanks for the offer, but i actually finished the job a few hours ago and everything is fine now! i have one other problem now... i have a bent rim up front, but it's not nearly as bad as the rear was... i just need to replace that rim and all will be well... it's a stock rim, 6 lugs, 15" if anybody can help me out...
the stupid thing makes a very annoying sound and rubs a little bit... a little shake, too... i don't really think i should drive it too much till it's replaced... I NEED A RIM!
thanks again
Old 04-19-2007, 09:55 PM   #12
Srubydo1986
The Crazy Machanic
Re: axle questions!
nope got non of those I really wish had a 4x4 now.
newest additions
