Old 04-27-2002, 02:23 PM   #1
Dual quad
Smell that burnin' rubber
Dual quad's Avatar
Post 700R4 Driveshaft question
Boys - I’m getting close to installing a 700R4 in place off my 350TH. I’ve measured both transmissions and the 700 is about 3” longer. The existing driveshaft in the truck is a split with hanger bearing that I want to keep in case I want to change back to the 350 someday.
Should I just have a new single shaft made up for this application? Or should I find another primary shaft and have it shortened to work with the existing split setup?
'72 SWB Cheyenne, L-31 Vortec 350, 350TH, COMP 260H Roller cam, Edelbrock RPM intake and 1405 carb, 3.73 posi diff.
Dual quad is offline   Reply With Quote
Old 04-27-2002, 03:01 PM   #2
Smitty
Smitty's Avatar
Post
If you go with a one piece drive shaft chances are that you will have to remove the bracket that your carrier bearing mounts to otherwise there will be interference with the drive shaft as it passes through this crossmember. If you go back to a 350 which I doubt you could use a one piece driveshaft for it too!
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 04-27-2002, 04:10 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
have one made or cut down one trhats too long for what you need, have to find one in junk yard under something GM with a 700r4 or a 3 or 4 speed car tranny or a th350
doesnt matter if U joints are wrong size, conversion joints can be gotten at napa although they are pricier, around 27 bucks each sometimes more
can have shafts made for 150 or 200 these days at driveline shops
Randy- Lincoln, IL
r68c30@hotmail.com 2177353230
-71 C-10 350/CH465/3.07, assemble it, yeah right, that'll happen in this world,(not)
-84 Z28 Camaro 5.0L 700R4, 3.73, beater, paid way too much for it like an idiot,,
-84 Firebird SE 2.8L T-5, rod knocking, dammit,,
-82 Firebird 350 4bolt (TBL)/TH350, not running, dammit...
buy/sell/hoard/trade most any GM vehicle parts of any kind
-parting out: '81 Cutlass Supreme Brougham
*Paint is overrated
© RSS Enterprises 2000
Fast68Chevy is offline   Reply With Quote
