yeller
updated pics, need your opinions too
Got my front clip installed today (Saturday)...I am getting soo excited, I can finally see light at the end of the tunnel! The truck will be going in for final paint in May/June.
Now for my questions, and hopefully your feedback...but before that, some info on the truck. The front is droped 4" with 3" spindles and 1" drop springs. The rear is dropped approx 7-8 inches (depending on who you ask) with a flip kit and 2" drop shackles...and I removed the overload springs from each leaf (I have HD rear springs..but that shouldn't matter with a flip). As you can see in the pics, the truck is basically level, perhaps a fraction higher in the front. I would like the front lower OR the rear higher...but preferably the front lower. I was thinking 2" drop coils to replace my current 1" drop coils...sound like a good idea, or should I go with 2" drop coils. Whatever it is, I only want to do it once. I could relocate the rear leaf springs to the next hole on the shackles, essentially raising the rear...but I dig the rear stance and wheel placement in the wheel well. ![]() Anyhow, looking forward to your feedback! Thanks. ![]()
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
Re: updated pics, need your opinions too
First of all awesome looking truck.
Now for my opinion. The front does seem a bit higher than the back. I'm not sure if you want a slight rake, but if you do.......Raising the back, you would have to first level it and then raise it a bit more to have the front lower than the rear. That would completley throw everything off. I vote for lowering the front!! Back looks great at the height it is currently in.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 |
Cruzzzn' Vet
I would go with the 2" coils, the rear stance is perfect over the wheels, and once you get all the front end hung,bumpers,grill etc. you'll have a slight rake which will look killer on the truck, she's looking good
![]() John |
Garage Queen Material
truck is looking good man!
![]() but crap, MY truck sits lower in the back. i gotta get my front dropped more too. my current set up is: 3" spindles/1.5" coils in the front flip kit in the back and my front is still higher up ![]() i'll sell you a set of 1.5" western chassis coils if you want them ![]() |
The One And Only !!!
SWEEEEET lookin truck Jeff, And my favorite color !!!
I vote for dropping the front a little more also, The rear looks awesome.
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
![]() ![]() Join Date: Jul 2002
Yes, go with the 2" springs it should give it the look you want once everything is back on and things settle down.
cut a coil and you will be happy!
86 SWB 9.0 LITER T-400-OD 4.11 eaton-4/5 drop Best 1/4 12.51 @112mph no traction ![]() |
It'd be alot cooler if you did
I would also agree that the tire is nicely positioned in the rear wheel well. I would lower the front untill the front wheel is one inch closer to the wheel well than the back wheel is. then it would have the perfect rake.
I also vote for dropping the front a little. It sure does look killer though.
Chris
I agree sweet truck I love it.
I think too looking at the tires to well comparison the front seems higher but looking at the body seems level. I'd do the coils up front if you want to spend the cash and time to do it. I like that back how it is. Since it's flipped wouldn't you need to bring the springs down a hole and not up? I'd thinking going up a hole would lower it further right?
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
yeller
Thanks for the kind words and advice. The front will indeed come down. I will probabaly buy some 2 or 3" drop coils...but am worried 2" will not be enough and 3" will be too much.
Are flip kits generally 5 or 6" drops?? I still need to install the front bumper, grill and H/L's, inner fenders, and add all fluids...but I don't think all of that will help the nose bleed stance.
#12 | |
yeller
#13 |
Happy to be here
![]() Join Date: Mar 2000
He said "lower hole"! Can you say that on here?
Jeff- Lower it. Your not going to be happy raising it back up. ![]()
#14 | |
" Never look up a dead dogs butt." ![]() |
#15 |
Insert Title Here
trucks looking good... if it was mine, I would lower the front more, and get a little bigger tire out back
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
#16 |
well crap, i measured mine earlier tonight and my front is exactly 1/2" higher than the back is! i'm pretty sure it needs a 6/8 drop on it(my truck that is)
are you gonna keep the welds on there jeff? i sometimes think 15" wheels would look better on my truck than the 17's |
#17 |
dang its hot
how long has it sat without weight on the nose? coils settle so maybe you ought to wait till its done, drive it and see...
#18 | |
Happy to be here
#19 |
correct me if I'm wrong, but I believe the wheelwell cut-out is larger in front than in the rear. i would sooner think your sitting level. but you probably knew this,,...
-41-
1941 Chevy 1/2 ton Street Rod: 327 cu,/350 auto, 'Stinger ' - JULY 2007 CUSTOM CLASSIC TRUCK magazine. 1967 Chevy 3/4 ton standard bed, 350 cu./400 auto, w/ 83 - 3:43 rear end...sips gas.... |
#20 |
Looking great so far, love those wheels. Lower it just a little bit out front
![]() I see it's still gray up in the twin cities, I lived in Mendota Heights back when the Northstars were still in the NHL. The saying was 9 months of good skiing, 3 months of bad skiing, and good ice fishing all 4 seasons!
Kurt Instagram: @kurtkphoto 1978 C10 Silverado 1991 Camaro B4C |
#21 |
Chris
I agree with above I think after noticeing a few guys pics the wheel well opening is up higher, just look at where it has the curved section then the straight line, compared to the top of the opening, the bed is thicker there then the front so maybe it's level.
Guys also made a good point, after having something jacked up in the air or without weight you need to drive it and work the suspension to get it all settled and dropped into place. I think you'll be ok leaving it that way, but if you want I'd do the 2 inch drop springs, not 3, that'd give you a rake, but if you want rake it be great. I personally think it would be great either way, left alone, 2 inch or 3 inch.
#22 |
STILL PLAYS WITH TRUX
Jeff it's really comming togeather nicely im with every one else leave the rear where it's at and drop the front.
I was gonna say wait untill you have all the other front end components installed and let the front end & springs settel a week or so and see where she sit's remember everything up front is new and still tight. Im not sure if thats gonna by your final wheel & tire combo but you can allways lose an inch with a decrease in tire sidewall. |
#23 | |
Dark Heart Motorsports
How Deep Can YOU Bleed..? 1985 Chevy Blazer K5- 6.2 N/A, 400 turbo trans CUCV, 12v converted... a new chapter 2005 GMC Sierra Crew Cab 6.0 powwwaa!!! custom jumpseat install w/ captain seats, Hypertech tuner, MSD Blaster Coils, CB and twin antenna's, all electric interior, touch screen in dash. custom center console, with jump seat replacing original console. 1500 HD! |
#24 |
Until Seventy Times Seven
Jeff -
It's really looking good! ![]() I agree with the consensus to drop the front. If you have the suspension travel and wheel clearance, you may be able to go a couple more inches for an aggresive rake which could match the wheel combo. This would fill the front fender a bit more to get the front wheels closer to tuck. If the rake turns out to be too much, then maybe you could add a shim in the rear. (If you have the clearance, since it's gonna be low.. low..low.) And, you may have to add a spacer or offset the UCA shaft. If it doesn't work out, you could always jack up the front and turn it into a Gasser, especially with the big block. j/k ![]() Here's a chop with you current drop, another inch drop in the front and finally a 2" more drop in the front. It's looking good and should be tight once you get the color on it. ![]()
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... Last edited by boxrodz; 04-15-2007 at 05:02 PM. |
#25 |
yeller
I guess I should have provided more data on the drop. The front has been dropped this way since '97. The rear was originally a 4" drop (shackles & hangers), but I put stock hangers back on and flipped it over the winter...so now it has a flip kit and 2" shackles.
I understand the whole wheel well height difference, and I am basing my stance on the distance between the top of the tires and the bottom of the wheel well...I would like the front and back to be close to the same distance as possible from each other. Marcus, thanks for the photoshop...I believe the 2" additional drop looks the best!!! Thanks again for the help everyone.
