Old 04-14-2007, 06:04 PM   #1
mxer
mxer's Avatar
New to forum need some help
Ok heres what i got 70 with lowered front not sure if it has spindals or just springs,they got some kind of spacers in between the springs.The rear i beleive its stock.I just orderd 20x8.5 for the rear and 18x8 for the front with 5 inch b/s . I would like to go as low as possible but this truck has a bb and the headers are pretty close to the ground already.Not sure if i want air or not but if i can do it with air for around a grand that would be sweet too.Please any help would be appreciated.
mxer is offline   Reply With Quote
Old 04-14-2007, 06:08 PM   #2
SCOTI
SCOTI's Avatar
Re: New to forum need some help
Does the truck have disc brakes?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-14-2007, 06:10 PM   #3
mxer
mxer's Avatar
Yes it does
Old 04-14-2007, 07:27 PM   #4
SCOTI
SCOTI's Avatar
It's hard to say w/100% certaintly what you have (drop spindle vs. stock spindle) w/o having 1 known drop spindle & 1 known stock spindle to compare against. If you had drum brakes, we would know they aren't dropped spindles because they don't make drop spindles for drum brake applications.
You could always get drop spindles & compare them to yours. If they're the same, return the spindles.
I don't know what to tell you on the coils. I would definitely toss them for some cut down stock springs or aftermarket dropped springs. There's no reason to have the 'spacers' you described other than a weak spring.
You're going to need to bite the bullet & get some shorter headers if you want it real low. Get some 3/4 length headers for a 67-77 BBC Chevelle. They should fit w/minimal trimming on the top frame rail. I'm using some from Sanderson but several manufacturers make them.
I hope this helps. . .....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-15-2007, 09:32 AM   #5
mxer
mxer's Avatar
Ya the headers are a good idea but how about the suspension who's a good place to buy from.Like i said would like to bag it but also want to keep it a bolt on deal and dont really need the frame on the ground.
Old 04-15-2007, 10:24 AM   #6
SCOTI
SCOTI's Avatar
1st choice: Early Classic Enterprises
2nd: Classis Performance Products
3rd: Performance Online.com
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
