a arm question. 3/4 and 1/2 tons
I pulled down my 72 c20 yesterday to go through the front end (new upper and lower control arm bushings, ball joints, etc..) and found one of the bushings on the lower a-arm were worn into the a-arm itself. I have a couple of 1/2 ton 67 parts trucks.
Is the lower a-arms the same?
67 C10 396 stepside project 72 C20 402 72 K10 SWB (plow truck) 86 K20 |
Re: a arm question. 3/4 and 1/2 tons
The lower "A" arm shafts are the same but the lower ball joints are not. The lower ball joints mount up completely different as the C-10 ball joint presses in and the C-20 bolts in, (or is riveted). It looks like you will need to find an "A" arm for your C 20.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
#3 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Just go and find a 73-87 3/4 ton and get the lower a arm off of it. They are the same as 67-72 3/4 ton a arms. And I second the larger hole. I tried to put 3/4 ton ball joint in a 1/2 ton a arm. Big difference in the diameter Hope this helps.
#5 | |
I'll checkout the local boneyard to see if I can find one. A 73-87 should be a lot easier to fine. Thanks again for the help, I REALLY appreciate it. Bob
C10 s made the change to rubber bushings in 73. The 73-87 3/4 tons used the same a-arms and disc brake spindles as the 67-72's.
glad I could help. Last edited by Aarons72s; 04-18-2007 at 07:17 AM. |
