![]() Join Date: Jun 2000
Electrical short -- no panel lights
Trying to chase down a short in a '68. It's in the instrument cluster lights circuit (lower RH fuse). I unplugged the cluster and it still blows a fuse. Any (other) places in this circuit that are notorious for shorting out? I will be studying wiring diagrams for awhile tonight.
Ben '68 Chevy C10 Custom LWB 327/TH400 2nd owner '16 GMC Sierra 1500 SLE Dblcab 4wd 5.3 |
If im not mistaken, the parking light fuse feeds the cluster AND the parking lights. Check near the rear for hacked installs of trailor wiring.
Nope, parking lights still work.
Well, I got the panel lights working. Don't know what I did but I took it all out and put it all back in and it works OK now.
![]() Now to fix the other problem: the LH headlight and blinker circuits are crossed, so the blinker comes on with the bright lights and the bright headlight blinks when I signal. They work fine when I unplug the cluster so I guess they're crossed on the circuit board. Time to order a new one... ![]()
lol whoa what a mess
![]() Check the wiring to the connector, make sure no one has butchered it and crossed the High beam indicator light with the LH signal indicator light. |
Recovering Truck Driver
i'm guessing you have a big bad ground problem somewhere, that is usually the cause of the blinkers comming on, or just one blinker with the headlights, or taillights, at least in my experience. I had alot of these problems running classic semi-trucks for 5 years.....big power, pretty trucks, more wiring problems than Carter's got pills!!
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
Did this just start happening?
If so do as O'l Buck said and check your ground wires closely. If it has always (or since you have acquired it) been that way check the color code on the connector on the plug to the printed circuit to the dash this link will help Tech Tips You also may want to look closely at the printed circuit on the back of the dash these are repaired rather easily. I have also seen weird things happen when the emergency flasher is partially depressed on the column switch. I hope this helps
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
Unfortunately this isn't my truck, I've done work on it ever since my 82 year old friend found out I know these trucks pretty well. He bought it new in '68, and it's a pretty nice mint green C10. (I'll have to get pics sometime.) So I don't know when all these problems started, and I'm usually patching up stuff that the previous hack mechanic did. (hehe I feel sorry for the guy who has to follow me!
![]() I'm expecting to get a new circuit board for it, and think I should also get a light switch. That should fix all the lighing problems, but now the blower motor isn't working. I'll post a new thread for that one... ![]() I think what we have here is a bonafide gremlin! ![]()
Did some work on it this weekend. The headlight/blinker problem was due to a pair of crossed/twisted tabs where the wiring harness plugs into the cluster. One was hanging by a thread and came off while I was repositioning it. New printed circuit board from Kenny's: $50. Maybe that will fix the short in the cluster lights, too.
The A/C problem is either the fuse box or the relay. He needs a new fuse box anyway so I'm already replacing it (got one for sale?), and I ordered a new relay from Kenny's just in case; $15.
