Old 04-15-2007, 01:56 PM   #1
JEC32
coilover vs. must.ll
Looking for anyone out there with knowledge of the differences in handling of these set-ups?
JEC32 is offline   Reply With Quote
Old 04-16-2007, 10:09 AM   #2
1-ton of fun
polishing a turd
1-ton of fun's Avatar
Re: coilover vs. must.ll
do you mean coil-over vs. non-coil over on a mustang 2?
the spring rates and shock valving would be the main factor. the main benefit of coil-overs is adjustable ride height, and a wide range of spring rates available
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 04-16-2007, 04:21 PM   #3
Ed ke6bnl
The adjustable ride hight would be nice since I put a mustang II on my 50 F1 ford and after a few years and settling it sits too low. I will probably go with air air ride suspension that replaces the spring and shock for the adjustability. Air ride was not an a practicle option about 6 years ago. I do say that the mustang II has a great ride as it is now. But it doesn't do well going down my dirt road that low to the ground. Ed ke6bnl My 53 chevy is going with a 85 S10 frame swap when time permits.
Ed ke6bnl
Agua Dulce
70 S.E. Los Angeles
70 Chevy short bed
1948 F3 ford pu
1949 F1 stock V8 flathead 3 on floor
1950 F1 pu street rod
1948 F6 Ford Dually/350sbc no bed stock trans&rear
1972 El Camino 4" chop
1953 Chevy 3100 2b daily driver
1970 SB 4X4 400ci 6in lift
Ed ke6bnl is offline   Reply With Quote
