04-15-2007, 05:26 PM | #1 |
Power Steering Pump & Bracket $50.00
How about $50 bucks for the pump, pulley and bracket. PayPal prefered.
Spins good, not burnt up, will need new hoses.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!" |
04-15-2007, 06:16 PM | #2 |
Re: Power Steering Pump & Bracket $50.00
Will ya do 50 shipped to Spokane Wa
Support The Board |
04-15-2007, 06:20 PM | #3 |
It's pretty Heavy, How about $60 shipped. Maybe I can sneak it into a prepaid box? Let me know. PayPal prefered. Thanks
04-16-2007, 02:16 PM | #4 |
Can you put me in line?
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
04-16-2007, 03:19 PM | #5 |
Son of a gun
They don't fit in flat rate boxes, I've tried
Bill BEATERS ARE NEATER |
04-16-2007, 03:21 PM | #6 |
jorgensensc your next up in line
04-16-2007, 03:24 PM | #7 |
Jorgensenc it's yours, How is $60 shipped. If it cost less then I will send the money to you if it cost more, then it is on me. PayPal prefered to griffithauto@yahoo.com
04-16-2007, 06:27 PM | #8 |
Do you have any 6 cyl. pumps? Rob
I guess you could say I’m not really lazy I’m just real good at doing nothing!!!! |
04-16-2007, 08:28 PM | #9 |
Perfect, just a few clarifications please. Does it have any leaks? Was it taken off a running truck (so you know it works?) How is the pulley, is it bent or chewed up on the edges? And lastly, do you have an extra set of hoses that are not cut?
04-16-2007, 09:02 PM | #10 |
Sorry, no hoses. It was taken off a running truck. Pulley not bent up. Does not leak. I will guarantee it to work, if you install it and it doesn't work (WHICH IT WILL WORK) I will refund you the money.
04-16-2007, 09:43 PM | #11 |
Great! Paypal sent. Now to find hoses for cheap! Will hoses off later model trucks work? ie 73-87? There are plenty of those over here, but not any 67-72 in the j-yards. On a side note, I have manual steering, I have a power steering gear box with arm. Will the rag joint (steering coupler) I have work? or do I need to get one from a power steering truck? I am soooooo ready for power steering!
Thanks! Shawn
04-16-2007, 10:01 PM | #12 |
Not sure of the tech questions. I would bump this question over to the other board. Infact I jsut did for you. PayPal recieved. Will ship out tomorrw most likely.
04-16-2007, 10:58 PM | #13 |
Watch out for your cornhole !
You got a good deal.
Tech: You need the rag joint for the power steering box. It's different than manual steering rag joint. You're going to need the bolt on crankshaft pulley for power steering. It stacks onto the stock pulley with longer bolts. They're sometimes hard to find. Don't sweat it if the power steering pulley were to be a little bent. They are thin metal. Just install the pump onto the engine and use a crescent wrench on the lip of the pulley to tweak it straight. No biggie, they are pretty much all a little wobbly by now. Tweak and rejoice in the straightness. The power steering hoses are parts store stuff. I got some at O Reilly awhile back.
04-16-2007, 11:09 PM | #14 |
As always thanks for the info Tx! I was torn between going LWP (which I bought, and I have the right lwp pulleys) and staying with the swp that is on there (but with incorrect water pump pulley, they don't align correctly). This purchase made the decision for me. The crank pully has 2 grooves on it already. Can I use the other groove? Also what can I do when I decide to add A.C.? Do I just bolt on another single groove pulley to the crank? Thanks!
Shawn
04-16-2007, 11:16 PM | #15 |
Rear groove (closest to engine) is water pump and alternator.
second groove is A/C if equipped, empty otherwise third groove (closest radiator) is for power steering. There are a couple of different lower pulley configurations. Usually, it's a steel 2 groove pulley with the 3rd groove pulley ,which is made of cast iron and quite heavy, stacked onto it with 3 longer bolts.
04-18-2007, 07:51 AM | #16 |
Work has me delayed, I should ship tomorrow Sorry.
04-24-2007, 02:51 PM | #17 |
Sorry, I thought that this had already shipped. Here is the confirmation #
420770189101150134711833520461 USPS Priority Mail Thanks Army
