Old 04-15-2007, 08:19 PM   #1
snacob14
What year van for tilt column
Just need to know what year chevy van's I should look for to do the tilt column mod. I searched and found nothing about the years
snacob14 is offline   Reply With Quote
Old 04-15-2007, 08:23 PM   #2
southern parts
southern parts's Avatar
Re: What year van for tilt column
70-81 vans. You might want to look in old motor homes too. Woody
southern parts is offline   Reply With Quote
Old 04-15-2007, 09:30 PM   #3
krue
Designated A-hole!
krue's Avatar
Just look and make sure the key is on the dash, not the column.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 04-16-2007, 05:39 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
72 - 81, and some 82's were the old style too.
Old 04-16-2007, 05:52 AM   #5
brak
brak's Avatar
I'll jack this thread since the following question could be beneficial to him too...
Do the van tilts use the same internals as the truck tilts, such as bearings signal switch, gear indicator, etc.??
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 04-16-2007, 07:33 AM   #6
Bob Moore
Brak - basically yes. I have both -truck & van - and have found the only real difference is the length of the shaft. The van gear indicator lens has a different letter style from the original truck. The re-pop lenses are of the van style. I have not found a source for the original truck lens.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 04-16-2007, 07:58 AM   #7
msgross
msgross's Avatar
Not sure if this is a good techniques but I focused my junkyard search on chevy vans with round headlights. Sure enough, I found two last time I was at the yard.... When you pull them don't bother with the rubber piece bolted to the firewall, the bolts are hard to remove. I removed the two on the rag joint and two under the dash and it pulled right out in 10 minutes...
Mike
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
