Old 04-15-2007, 09:44 PM   #1
superman3405
Junior Member
superman3405's Avatar
new gauges...pics please
I am thinking of taking the factory gauges out of the 72 and replacing with updated newer gauges. Have any of you done this...if so do you have any pics I can see before I make my mind up? Thanks Don
1972 Chevy C-10 Short Bed (Ol'Blue)
350/350TH
2003 Chevy Silverado Z71
2007 Honda MiniVan...yup we should all be so lucky
superman3405 is offline   Reply With Quote
Old 04-15-2007, 09:55 PM   #2
killer71
killer71's Avatar
Re: new gauges...pics please
I'm getting ready to go Fuel Injected and these are what I will be going with.
R.I.P.
Killer 71
10/26/07
killer71 is offline   Reply With Quote
Old 04-15-2007, 10:43 PM   #3
superman3405
Junior Member
I like that, as far as installation was it hard? The middle gauge what all is on that??
350/350TH
Old 04-15-2007, 11:42 PM   #4
killer71
killer71's Avatar
They will be all electric haven't got em in yet;
R.I.P.
Killer 71
10/26/07
Old 04-16-2007, 12:12 AM   #5
jackyl9999
jackyl9999's Avatar
There is quite a few folks doing these. Depends on your taste in gauges. Good luck with the project.
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 04-16-2007, 12:17 AM   #6
72CSTC5
72CSTC5's Avatar
That is the same setup I am going with in the Cheyenne Killer. For some odd reason my truck was only optioned with the idiot lights.
72CSTC5 is offline   Reply With Quote
Old 04-16-2007, 12:22 AM   #7
dan42
dan42's Avatar
jackyl9999 - is that a dimmer switch on top of the clock? Did you get those pre- made or did you order those separately? It looks really nice.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 04-16-2007, 12:29 AM   #8
jackyl9999
jackyl9999's Avatar
That is my high beam indicator above the clock. I bought the gauges, a new new bezel, got 1 piece of lexan, and a aluminum plate to mount the clock in. It was quite a project. btw the turn signal and high beam ind. are painless lights. Thanks !
1990 K1500 Daily
Old 04-16-2007, 07:15 AM   #9
KFreddy
Active Member
KFreddy's Avatar
Killer71,
Did you have to mix and match those autometer gauges? I was under the impression that the quad gauge only came in a kit of sorts. I've been wanting to do the same set up with black face gauges. Not trying to hijack anything here post wise, just curious.
-Fred
KFreddy is offline   Reply With Quote
Old 04-16-2007, 11:59 AM   #10
Mudder
Mudder's Avatar
There are 2 or 3 3 3/8 Phantom oil pressure guages on evil bay was I type.
Mudder is offline   Reply With Quote
Old 04-16-2007, 12:07 PM   #11
fatboys69
fatboys69's Avatar
Here's my set up Covan's panel with Autometer Ultralites. A bit $$$ but I like them, way more accurate than the factory gages !!
fatboys69 is offline   Reply With Quote
Old 04-19-2007, 05:30 AM   #12
KFreddy
Active Member
KFreddy's Avatar
I'm curious where you found these? I am only seeing them sold as a kit, tach with quad or MPH with quad were you able to buy them as seperate gauges? Also are the sizes you used 5" for the tach and MPH and 3 3/8 for the quad?
Thanks,
-Fred
"The Great State of Florida"
Old 04-19-2007, 12:31 PM   #13
Yukon Jack
Post Whore
Yukon Jack's Avatar
Here are the AutoMeter Phantom guages I am using (I later swapped the tack and speedo to the opposite positions).
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 04-19-2007, 02:33 PM   #14
shifty
Questionable
shifty's Avatar
Originally Posted by KFreddy View Post
Killer71,
-Fred
http://autometer.com/cat_gaugedetail...earch&gid=3591
3-3/8" quad guage Autometer part # 1312 (or #1612 or there are others)
http://autometer.com/cat_gaugedetail...earch&gid=3483
5" Tach Autometer part # 1399
http://autometer.com/cat_gaugedetail...earch&gid=3308
5" Speedo (elec, programmable) Autometer part # 1389
He's doing a GenIII swap also, I think gringoloco is too (?), so we can get away w/electric speedos.
I need to screw around some more and find something fitting for me. I'll miss the old blinkers unless I can find someway to mount them somewhere.
If you want to buy these parts separately, go to jegs.com or summitracing.com and type in the four-digit number of the Autometer part, and you'll find it there.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
