Old 04-15-2007, 09:48 PM   #1
PaulY
3 on tree to auto column swap
Any advice on swapping a 3 on the tree to an auto column? I have an auto column from a 63 to put in my 63. I have noticed the wiring is different, but will it plug into the same harness? Anyone have a wiring diagram for 63 columns?
PaulY is offline   Reply With Quote
Old 04-16-2007, 06:26 PM   #2
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
Re: 3 on tree to auto column swap
The only difference in the wiring that I can think of is that on a automatic steering column, there will be a switch mounted at the base of the column for a neutral safety switch, which should also work for the backup lights, plus an addition wire that will have to plug into the fuse box for the light to light up the ishift indicator. Other than that, the wiring should be the same I would think.
David
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
Old 04-16-2007, 09:28 PM   #3
PaulY
Thanks! That is what I am hoping.
