04-15-2007, 11:29 PM | #1 |
too many toys
brighter headlights
I found that "BOSCH " does carry headlights for our 4-light trucks. Just not in a kit. You need to ask your local supplier for these part numbers. I put-em in my 70 gmc 3/4 4x4, wut a difference. Just remember to put a relay to each light. part # 0 301 302 101 low/high beam lens uses H-4 bulb
# 0 301 303 034 high beam lens uses H-1 BULB. I put an H4 140 watt and H-1 100 watt set and WOW.... again DON'T FORGET TO USE RELAY'S FOR EACH HEADLIGHT.......
if we were all fatter we'd be closer together 1971 gmc 3/4 4x4 383 stroked 1968 1/2 2nd owner 4bbl 6cyl 1969 gmc 3/4 4 sale 350 4bbl 4spd 1969 chev 1/2 lowered 5 spd 454 4bbl 1947 chev coupe 2002 harley flhtcui 6 -67-72 my parts |
04-20-2007, 11:12 PM | #2 |
Re: brighter headlights
Good to know
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
04-21-2007, 02:49 AM | #3 |
cool deal, bright headlights or just highbeams can be fun
-steven Alte Seele S.S. "Allison" '72 C/10 LWB 350SB/TH350 - DD PITBULL IS NOT A CRIME |
04-21-2007, 08:04 AM | #4 |
Active Member
I'd like to try this on my GMC. Any suggestions on wha type of relays?
I bought a set of relays for my chevy from Mad Electric some time ago, but never put them on. Driving the GMC the other nite, the lites seemed really yellow.Where did you get your relays? What brand?
68 short fleet 383 stroker, 700r4 373:1 posi 72 GMC 3/4 ton- weekly driver 700r4 351;1 posi |
04-21-2007, 08:12 AM | #5 |
Post Whore
Curbstone Mech, there is a good post in the FAQ section about upgrading lights and relays - it should help.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
04-21-2007, 08:28 AM | #6 |
We also carry the crystal clear headlights & bulbs for the Chevy 7"& GMC 5 3/4" headlights.
You'll find them here http://www.gmcpauls.com/headlights.htm We also carry the wiring harness with relays to get the maximum light output out of them though we haven't had a chance to add these to our online catalog yet. GMCPaul |
04-21-2007, 08:52 AM | #7 |
Active Member
Well, that's that. Might as well buy them from a sight vendor who's always there to answer any questions.
04-21-2007, 08:40 PM | #8 |
fabricator of anythng not wood
you can now get h.i.d. bulbs and ballasts to fit 7" and 5 3/4" like gmcpauls above
