Old 04-16-2007, 06:42 AM   #1
steveon3
Junior Member
gear swap
does anyone know if you can take the carrier and pinion and ring gear from a 67 closed knuckle and put it in a 74 front end? They are both dana 44 housing. with the 74 being an open knuckle? The old one has 456 gears that i want to use.
steveon3 is offline   Reply With Quote
Old 04-16-2007, 06:08 PM   #2
Eichorst69
Re: gear swap
Yes, I took the carrier w/ ring and pinion out of my 69 closed knuckle dana 44 and put it in a 72 dana 44 open knuckle. The housings are the same. You will need to use the 74 inner & outer axles though.
Rob
Eichorst69 is offline   Reply With Quote
Old 04-16-2007, 08:38 PM   #3
steveon3
Junior Member
Re: gear swap
thanks eichorts, I want to keep my closed knuckle front end, but Im having problems finding spindles for it. so if i go to a newer frontend, then i can have power brakes and power steering.
Old 04-16-2007, 08:40 PM   #4
steveon3
Junior Member
Re: gear swap
Thanks Eichorst69, sorry on my spelling.
