Old 09-08-2002, 12:27 AM   #1
dhenthorn
Smile Header bolts w/ Accessories
I am trying to put my Factory A/C back together and need some suggestions on what to do about the header bolts. I have bought the Hedman adapter for mounting the A/C compressor on the right side of the engine and it works out perfectly. My problem is that I have to use a 3/8"x16x1" bolt which places the 12 point head right next to the header tube which is a real pain to get a wrench onto. Can anyone suggest a better fix for this.
Thanks,
dhenthorn is offline   Reply With Quote
Old 09-08-2002, 02:44 AM   #2
jlmtrout
Have you looked at the ARP header bolts? They use a 3/8" head and are very strong. Good luck and keep on truckin'!......Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
Old 09-08-2002, 10:32 AM   #3
MOTHERTRUCKERS
allen head bolts maybe?
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 09-08-2002, 12:22 PM   #4
dhenthorn
I tried that but the head was too big to clear the header tube.
Old 09-08-2002, 09:01 PM   #5
Mike C
Mike C's Avatar
Buy a set of "long" header bolts. I ran that same bracket on my Heddmans for 10 years, but switched to 2 1/2" rams horns and the factory bracket. FYI, don't lose your original like I did, cost $60 to replace...
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
