Old 04-16-2007, 05:13 PM   #1
Houston54
58 Apache Project
Even though I am not complete on the 54 yet (getting closer) I had this 58 fall into my lap recently and it was too good to pass up. The only problem was it came to me without any axles, suspension or wheels. It did come with a Fatman IFS but I think I will use that on my big window 59 and put a camaro subframe, ala No Limit Engineering method, on the 58 but the first order of business was to get a rear axle on the truck.
I located a 1970 Camaro 10 bolt on Craigslist and some task force rear springs from another local trucker. Coupled with a new set of spring perches my son and I bolted everything up this weekend. The frame will need to be C notched to provide additional travel but for now it fine as is.
Is this how others have set up their task force truck rear leaf suspensions? I heard about lowering shackles but have not seen any.
Here are some pics of the rear axle installation:
http://www.picturetrail.com/gallery/...38&uid=2902753
I hope to get the sub-frame installed soon and will add pics from that also.
Houston54 is offline   Reply With Quote
Old 04-18-2007, 08:52 PM   #2
hammered65
Re: 58 Apache Project
Looks like a nice project.
hammered65 is offline   Reply With Quote
Old 04-19-2007, 10:57 AM   #3
1-ton of fun
polishing a turd
1-ton of fun's Avatar
glad you found an axle for it. i still have the 3/4 ton axle that i'm trying to give away.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 04-19-2007, 07:48 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
when can I come get it?
dwcsr is offline   Reply With Quote
Old 04-23-2007, 10:05 AM   #5
1-ton of fun
polishing a turd
are you the one who called about it? if so i emailed you back.
