wiring plug adaper
These convert your van column wiring plug to the stock harness curved plug. Im giving them with the van columns Im selling on the parts board. Here's a pic of wht they look like.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
looks like the ones GM supplies with the repacement signal switch assemblies(black round hazard knob instead of correct red push stick deal)
Your right.
do i win a prize ?? :PPPPPP
You win a free vintage wheel barrel. Shipping is only $500 US dollars, satisfaction guaranteed.
Classic Ind. has those
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
Hey, I've got one of those cramed up under my dash with the rest of the rat's nest of "modified" wiring!
![]() Anybody got any ideas? Kent ![]() I will try to get a pic of the column, but can't find that silly digital camera right now!
'56 F-100 (w/all GM stuff) Lookin' for another parts chaser! ![]() '05 GMC crew cab Last edited by fatfords; 09-12-2002 at 01:32 PM. |
Those plugs came in the replacement signal switch kits for years, just the basic kit came with it, even if you didnt need it.
Someone may of replaced the turn singnal switch, which is pretty common. You can tell van columns from truck ones but you have to have compared the two beside each other to recognize the differences. Look at the neutral safety switch. If it is designed to move with a tab sticking up into the neutral safety switch which has a groove to accept the tab, then its good chance its original truck column. Van columns have holes cut out higher up the column shaft then truck columns. Van columns have neutral safety that has a tab from the switch sticking into a hole in the inner tube of column. Little things like correct signal arms, correct wiring plugs,lenght of shaft out the bottom. Lenght of the shifter arms. There are differences. Horn assembly, type of hazard switch knob. etc. But van columns will work with a little bit of mods. Tilt van ones are popular.
i am unsure and wish i knew why ppl think that only van columns have flat style wiring connector, all 73-up have flat style as far as ive ever seen. half moon went bye bye in 73 in everything. the half mopon to flat adaptors are everywhere and cheap and come with new switch assemblies from GM at least, dunno about aftermarket suppiers, unless they are from GM(NOS or GM new replacement)
good luck |
Rod, thanks for the tips. I will check it out this weekend as I plan to try to clean up some of the wiring mess.
Fast68, I guess I just assumed if it wasn't the original, it looks like OEM, and all of the posts regarding changing columns all reference the van columns. Anyway, thanks for all the help. Kent ![]()
'56 F-100 (w/all GM stuff) Lookin' for another parts chaser! ![]() '05 GMC crew cab |
