Old 04-16-2007, 08:15 PM   #1
VDOG
Grand PooBaa Member
VDOG's Avatar
Gear Numbers
When I opened my 12 bolt, it had about a pint of gear oil in there.
There were some numbers on the ring X 3817779 14:43 CM 4-69 2
Dose anyone know what that means?
VDOG is offline   Reply With Quote
Old 04-16-2007, 08:24 PM   #2
Blue85
Oilfield Trash
Blue85's Avatar
Re: Gear Numbers
3817779 is the part number, 14:43means 3.08 gears, i'm guessing the 4-69 is a date code
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 04-16-2007, 08:48 PM   #3
Bus Ted Knuckle
Son of a gun
Bus Ted Knuckle's Avatar
Re: Gear Numbers
14:43 is 3.07 gears. Blue is correct on everything else
BEATERS ARE NEATER
Bus Ted Knuckle is offline   Reply With Quote
Old 04-17-2007, 01:21 AM   #4
Goodguytrucks
Re: Gear Numbers
If it has springs inside also ....Does it mean it is a posi?
Goodguytrucks is offline   Reply With Quote
Old 04-17-2007, 09:34 AM   #5
Robznob11
Robznob11's Avatar
Re: Gear Numbers
yup
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 04-17-2007, 12:07 PM   #6
Goodguytrucks
Re: Gear Numbers
I didn't know if it was just some limited slip or posi....Well that is good cause that is what is going in my truck then
Old 04-17-2007, 01:09 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Gear Numbers
Your center pin retaining bolt is either broke or missing.
Old 04-17-2007, 01:17 PM   #8
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: Gear Numbers
Good eye.
sneakysnake is offline   Reply With Quote
Old 04-17-2007, 01:48 PM   #9
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Gear Numbers
Yes it is broke. I found that out when I was removing it to take the center pin out. Half of it unscrewed, and other half is still in the hole. Was told to beat it out, but thats not working, so I have to get an Easy Out to remove it.
Old 04-17-2007, 02:06 PM   #10
RACINJASON22
GEARHEAD
RACINJASON22's Avatar
Re: Gear Numbers
Good LUCK with that one! It has happen to me and it can be a real PITA specially after you have tried to beat the cross pin out. It can be done though I got it in the end.
72 SWB 2WD MY PROJECT
72 LWB 4X4 FUTURE PROJECT
SUBSCRIBE HEREBOARD VENDORS HERE
NORWOOD MEET SURVIVOR!
RACINJASON22 is offline   Reply With Quote
Old 04-18-2007, 02:43 PM   #11
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Gear Numbers
I think 2 days of beating is enough. Time for a new plan.
Old 04-20-2007, 04:19 PM   #12
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Gear Numbers
3:08's, I think I might as well change those also. With this 283 in my truck, im going to need all the help I can get. Do you guys think 3:55's or 3:73's will be better?
Old 04-20-2007, 05:36 PM   #13
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Gear Numbers
well, if you spend much time on the freeway, you'd be best off with those 3.07 gears. (the 3.08 was a car gear, 3.07 was for trucks)
Old 04-20-2007, 05:36 PM   #14
SactoJim
SactoJim's Avatar
Re: Gear Numbers
Definately get better gears. That little 283 doesn't have much torque. Go with 3.73''s.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 04-20-2007, 06:16 PM   #15
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Gear Numbers
Dont spend a lot of time on the freeway and besides in Los Angeles, your not going to fast because of traffic. Will 3:73 let me drive the freeway and give me some added torque?
Old 04-20-2007, 06:23 PM   #16
Longhorn Man
Re: Gear Numbers
well, there is another way of looking at this...
the 3.07 is already there. Get your truck on the road now, spend money where it needs to be spent to get you rolling... THEN... if you aren't happy with it... THEN, locate you a 3.73 axle. Your 3.07 is in higher demand for the freeway cruisers, so it'll be easy to sell.
And... we both know, LA isn't ALWAYS grid lock. otherwise, we'd never get the cool videos from the chopper on the scarey police video shows.
Old 04-20-2007, 06:29 PM   #17
VDOG
Grand PooBaa Member
VDOG's Avatar
Re: Gear Numbers
Yes we do have a lot of high speed chases here,..even in traffic.
Not a bad idea, now I have to research which trucks came with 3:73 gears.
I did pull 3:55's (I think thats what they were) from a 6 cyl 68 or 69 C10.
Cant remember and instead of taking the whole rear end. wheels and all, I took out the ring and gears and could not get the pinion out. I hear you dont mix one ring to another pinion. Unless one of you have tried it with no problem.
Old 04-20-2007, 06:46 PM   #18
mnunn454
mnunn454's Avatar
Re: Gear Numbers
If you change gearing above 3.42, you'll need a different carrier all together. Personally, I'd leave it at 3.07 and [assuming you have an automatic] if you want more pick-em-up in your pick-em-up, get a higher stall converter.
69 C-10 SWB Fleetside 454/TH400 (For Sale)
http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12
70 El Camino 454 TH700
29 Model A 4-DR Sedan Deluxe
mnunn454 is offline   Reply With Quote
Old 04-20-2007, 06:56 PM   #19
Longhorn Man
Re: Gear Numbers
personally, screw setting up gears... esp if you are dealing with old used stuff. I'd just swap the whole rear.
3.73 gears would be in most 3 speed manual trucks, both inline, and small block.
#.73, 3.07, an ocasional 4.10, and I think some big block 3.42 gear sets is all you'll find in a stock 1/2 ton axle. (not sure on the 3.42.. .that may only be in the 3/4 ton and one ton trucks)
Old 04-21-2007, 04:13 AM   #20
GREASEMONKEY72
GREASEMONKEY72's Avatar
Re: Gear Numbers
personally id stick with the 3.07's, better mpg city or freeway, but if you do change i wouldnt go any lower then 3.73's and go with a whole rearend and not just the gears, then you know the splines are right and everything
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 04-21-2007, 04:15 AM   #21
GREASEMONKEY72
Re: Gear Numbers
IIRC, you can pull a rearend out of a newer truck or suv and get the 3.73's and rear disc brakes if you want
-steven
Alte Seele S.S.
Old 04-21-2007, 08:47 AM   #22
Re: Gear Numbers
I have a 3.42 posi unit for a 12-bolt.
Old 04-21-2007, 11:10 PM   #23
alschevy
Re: Gear Numbers
ok my 1967 chevy one ton tow the guy that i got my tow truck from when he got it the rear gear was a 538 and engine was a 250 six than the gear was a diffent one add it 456 now i have a 411 gear in it and my enging is a 305 but i will puting in a 292 six than later a 327 or 396
alschevy is offline   Reply With Quote
Old 04-21-2007, 11:34 PM   #24
AuggieStyle
AuggieStyle's Avatar
Re: Gear Numbers
Is there a formula to help decipher the code on the rear end to help find the gear ratio?
How does 14:43=3.07?
AuggieStyle is offline   Reply With Quote
Old 04-21-2007, 11:41 PM   #25
Longhorn Man
Re: Gear Numbers
You can do it, but then you have to fab up the panhard bar mount, and weld on new mounts for the trailing arms.
Disk brakes in the back of a truck is a total waste of money unless you constantly have a lot of weight in it.
none of that matters, we are talking 1/2 ton stuff, those gears were for the heavy trucks, not the light duty stuff.
Yes there is... divide 43 into 14, and you'll get 3.071428571... or 3.07.
