Old 04-16-2007, 08:42 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
bump stop on the new strong arms..
The new strong arms I got have a bump stop in the kit where have you guys mounted yours as there does not seem to be any pre drillerd holes?? Btw nate I got the new shocks and mounts just have to re drill the holes in the frame to mount em since I filled in the holes.... thanks for the great service nate and tony from air ride... both are great people thank you..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-17-2007, 12:48 AM   #2
gringoloco
A guy with a truck
gringoloco's Avatar
Re: bump stop on the new strong arms..
I've seen most guys put it on the corner of the upper plate. Just replace one of the nuts/bolts with the bumpstop. The arm should contact it when aired out.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 04-17-2007, 07:51 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
Thanks Il put that on the list of things to do..
MEMBER #6377
Project "7DEUCE"
