Zappaphile!
Radio Delete?
anyone have any pic's of a radio delete installed or a good source for one.
I have some hack job conditions on my dash, and am wondering if a delete plate will be easier than reconstructing that whole mess.. thanks in advance
1969 C20 LWB Camper Special - The Beater.. 1998 Cheyenne V6 - 4/6 Drop - For The Son |
Recovering Truck Driver
Re: Radio Delete?
it's been awhile since I looked, but there used to be some on ebay once in awhile. I believe the plate just clips into the factory mounting holes for the radio.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
Zappaphile!
Re: Radio Delete?
would like to see one installed to know how much area it covers.
I will weld in a small piece if I need to on my lower half, just want to know soon, as I plan to start dash disassembly for paint/metalwork this weekend. hope to have it primed by the end of this weekend (weather permitting)
I make Models
![]() Join Date: May 2005
Re: Radio Delete?
Here is one from when my truck was still under construction.....
Re: Radio Delete?
Here's your trucks twin, just not in as good shape
70' C-10 SWB 71' C-10 SWB 2001 Audi S4 1994 Ford F-150 1974 Gremlin 1959 Apache (Will be For Sale soon) 1972 Chevelle (Will also be For Sale soon) |
Re: Radio Delete?
719 - you can see the size from the pics posted. The original mounting method had 2 spring clips that fit into the original holes on each side of the face. The original hole diameter was (i'm guessing 1 inch) used to retain the clip. The grips on the clips were at 12 and 6(top and bottom). I'm not sure how much material you have left. You may have to get creative.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
Zappaphile!
Re: Radio Delete?
pics were perfect, thanks guys.. I will have to do just a little bit of a build on the lower portion of my dash, but the delete plate will cover it all very nicely
Thanks for the replys guys, very much appreciated, now off to ebay for the delete plate =)
