Old 04-16-2007, 09:45 PM   #1
72armyswbtruck
72armyswbtruck's Avatar
348 Big Block
How can you identify the 348 vs the 409?
I have one in a 67 truck. Any info out there,
How much are they really worth?
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-17-2007, 11:26 AM   #2
60-66 Nut
Professional Beer Tester
Re: 348 Big Block
The last year for the W engines was 1965, so someone must have put the engine in that truck. The 348 had the dipstick on the driver's side and the 409 had it on the passenger side. The only problem is the dipstick tube goes into the pan and not the block, and the pans are interchangeable between the two engines. In forty years lots of stuff could have been swapped around so it's hard to know for sure. The only way to tell for sure is to check the numbers.
The car engines are worth more than the truck engines, but as the car motors get harder and harder to find the truck motors are getting a little more valuable.
You can find lot's of good info here: http://www.348-409.com
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
